Salinity not working
PostPosted: Thu Jan 25, 2018 4:18 pm
by Loose
I have an RA* and the salinity is stuck at 5.9.
When first setup, calibrated to 35 ppt, and salt added to the setup, it would show much higher than my refractometer (45 ppt with the refractometer at 35 ppt). On further attempts to calibrate it, it got closer, but not quite there. During one attempt, the salinity went to 5.9 and hasn't moved since.
I got another probe since I'd need two anyway (water change salt station) and the same results, a solid 5.9 all the time. I just received my second salinity module today (w/third probe as I forgot it came with one) and swapped it in and the salinity still doesn't move.
My code is below, any suggestions:
Another thing, when I go to perform a salinity calibration, my RA* cycles ports on my relay expansion box as if it were rebooting.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
#define Heater1 Box1_Port1
#define Heater2 Box1_Port3
#define Heater3 Box1_Port5
#define Salexp Box1_Port7
#define Return Box1_Port2
#define Topoff Box1_Port4
#define Skimmer Box1_Port6
#define QTFiltHeat Box1_Port8
    ReefAngel.Star();
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
    ReefAngel.FeedingModePortsE[0] = Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.FeedingModePortsE[1] = 0;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPortsE[1] = 0;
    // Ports turned off when Leak is detected
    ReefAngel.LeakShutoffPorts = 0;
    ReefAngel.LeakShutoffPortsE[0] = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.LeakShutoffPortsE[1] = 0;
    ReefAngel.LightsOnPortsE[1] = 0;
    // Add fourth temperature probe
//    ReefAngel.Params.Temp[T4_PROBE];
    // Displays Temp 4, 5, and 6
    ReefAngel.AddExtraTempProbes();
    // Use T2 probe as temperature and overheat functions
    ReefAngel.Relay.On( Return );
    ReefAngel.Relay.On( Salexp );
    ReefAngel.Relay.On( QTFiltHeat );
    // Ports that are always off
    ReefAngel.Relay.Off( Topoff );
    ReefAngel.StandardHeater( T2_PROBE,Heater1,770,790 );
    ReefAngel.StandardHeater( T2_PROBE,Heater2,760,790 );
    ReefAngel.StandardHeater( T2_PROBE,Heater3,750,790 );
//    ReefAngel.Relay.DelayedOn( Topoff,3 ); // Time is in minutes
    ReefAngel.Relay.DelayedOn( Skimmer,3 ); // Time is in minutes
    boolean buzzer=false;
    if ( ReefAngel.isOverheat() ) buzzer=true;
    if ( ReefAngel.isBusLock() ) buzzer=true;
    if ( ReefAngel.WaterLevel.GetLevel(2) <= 36 ) ReefAngel.Relay.Off( Return );
    if ( ReefAngel.WaterLevel.GetLevel(2) >= 81 ) ReefAngel.Relay.On( Return );
    if ( ReefAngel.WaterLevel.GetLevel(2) <= 45 && ReefAngel.WaterLevel.GetLevel(2) > 9 ) ReefAngel.Relay.On( Topoff );
    if ( ReefAngel.WaterLevel.GetLevel(2) >= 81 ) ReefAngel.Relay.Off( Topoff );
    if ( ReefAngel.WaterLevel.GetLevel(2) <= 9 ) ReefAngel.Relay.Off( Topoff );
    if ( ReefAngel.WaterLevel.GetLevel(1) < 72 && ReefAngel.WaterLevel.GetLevel(1) > 9 ) // Main Heater run-dry protection
    ReefAngel.Relay.Off( Heater1 );
    ReefAngel.Relay.Off( Heater2 );
    ReefAngel.Relay.Off( Heater3 );
    if ( ReefAngel.WaterLevel.GetLevel(3) < 99 ) // Quarantine tank run-dry proctection (no auto topoff yet)
    ReefAngel.Relay.Off( QTFiltHeat );
    buzzer=true;
    else ReefAngel.Relay.On( QTFiltHeat );
    ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX1++tf9HT7e2xzsveeJ58UUddShZ2D1rfts=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=Heater 1
// RA_LABEL LABEL_PORT12=Return DCP-10000
// RA_LABEL LABEL_PORT13=Heater 2
// RA_LABEL LABEL_PORT14=ATO (Level 2)
// RA_LABEL LABEL_PORT15=Heater 3
// RA_LABEL LABEL_PORT16=Skimmer
// RA_LABEL LABEL_PORT17=Salinity expansion
// RA_LABEL LABEL_PORT18=QT heat/filter
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT23=Port 23
// RA_LABEL LABEL_PORT24=Port 24
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT28=Port 28
Re: Salinity not working
PostPosted: Thu Jan 25, 2018 7:53 pm
Humm. Does the green led on the module light up?
Can you make sure the power supply for the module is working fine?
It's odd that even another module would give this result.
When calibrating, what number does it show on the screen?
PostPosted: Thu Jan 25, 2018 8:31 pm
by Loose
Yep, odd. Green light on both modules; with two different usb cords. When calibrating, the calibration value is '0' with both modules whether in the calibration solution, in tank water, or not in liquid at all. After the calibration, 5.9 showing as salinity.
PostPosted: Thu Jan 25, 2018 8:35 pm
Try another USB port on RA*. You should have two.
PostPosted: Thu Jan 25, 2018 8:45 pm
by Loose
I did try using two other usb ports on the expansion hub but I think it's all OBE (overcome by events) now.
I tried using the new power supply with the older module/probe and it began to work. I calibrated it as well and now showing 35.2 ppt. I then plugged the original power supply back in and it is still working. I guess there was something transient with the original power supply???
FYI. I use both ports on the RA*; one is connected directly to my relay and the other to my usb expansion hub (which is connected to the multi-water level and the salinity expansion).
