Re: Cloud Wifi Hub compile error
Posted: Mon Feb 12, 2018 9:58 pm
Try running the setup again while connected to the serial monitor and send the log again.
http://forum.reefangel.com/
mounted file system
*WM: Adding parameter
*WM: Cloud Username
*WM: Cloud Password
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 0
*WM: SET AP STA
Entered config mode
*WM:
*WM: Configuring access point...
*WM: ReefAngelCloudHub
*WM: AP IP address:
*WM: 192.168.4.1
*WM: HTTP server started
*WM: Request redirected to captive portal
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Scan done
*WM: K2GVR
*WM: -67
*WM: NETGEARcannon
*WM: -83
*WM: carlsenfamily
*WM: -87
*WM: HP-Print-BA-LaserJet 1102
*WM: -89
*WM: Sent config page
*WM: WiFi save
*WM: Parameter
*WM: Cloud Username
*WM: Loose
*WM: Parameter
*WM: Cloud Password
*WM: +++++++++
*WM: Sent wifi save page
*WM: Connecting to new AP
Checking Wifi Credentials
*WM: 3
Should save config
username: Loose
Start
saving config
{"mqtt_username":"Loose","mqtt_password":"+++++++"}
IP address: 192.168.1.30
Connecting to cloud server...
Connected
Subscribing to Loose/out/#
Loose/in: all:0
Loose/in: io:255
cloud:ATOLOW:0
cloud:ATOHIGH:0
cloud:EM:137
cloud:EM1:4
cloud:REM:3
cloud:BID:4
cloud:AF:0
cloud:SF:0
cloud:PWMD:0
cloud:PWMA:0
cloud:PWMDO:255
cloud:PWMAO:255
cloud:R1:247
R1:247
cloud:ROFF1:255
ROFF1:255
cloud:RON1:0
RON1:0
cloud:R2:2
R2:2
cloud:ROFF2:255
ROFF2:255
cloud:RON2:0
RON2:0
cloud:R3:0
R3:0
cloud:ROFF3:255
ROFF3:255
cloud:RON3:0
RON3:0
cloud:R4:0
R4:0
cloud:ROFF4:255
ROFF4:255
cloud:RON4:0
RON4:0
cloud:R5:0
R5:0
cloud:ROFF5:255
ROFF5:255
cloud:RON5:0
RON5:0
cloud:R6:0
R6:0
cloud:ROFF6:255
ROFF6:255
cloud:RON6:0
RON6:0
cloud:R7:0
R7:0
cloud:ROFF7:255
ROFF7:255
cloud:RON7:0
RON7:0
cloud:R8:0
R8:0
cloud:ROFF8:255
ROFF8:255
cloud:RON8:0
RON8:0
cloud:ALARM:0
cloud:PWMD2:0
cloud:PWMA2:0
cloud:PWMD2O:255
cloud:PWMA2O:255
cloud:WL:0
cloud:WL2:72
cloud:WL3:97
cloud:WL4:3
cloud:HUM:0
cloud:DCM:0
cloud:DCS:0
cloud:DCD:0
cloud:DCT:0
cloud:PWME0:0
PWME0:0
cloud:PWME1:0
PWME1:0
cloud:PWME2:0
PWME2:0
cloud:PWME3:0
PWME3:0
cloud:PWME4:0
PWME4:0
cloud:PWME5:0
PWME5:0
cloud:PWME0O:255
PWME0O:255
cloud:PWME1O:255
PWME1O:255
cloud:PWME2O:255
PWME2O:255
cloud:PWME3O:255
PWME3O:255
cloud:PWME4O:255
PWME4O:255
cloud:PWME5O:255
PWME5O:255
cloud:AIW:0
cloud:AIB:0
cloud:AIRB:0
cloud:RFM:0
cloud:RFS:0
cloud:RFD:0
cloud:RFW:0
cloud:RFRB:0
cloud:RFR:0
cloud:RFG:0
cloud:RFB:0
cloud:RFI:0
cloud:RFWO:0
cloud:RFRBO:0
cloud:RFRO:0
cloud:RFGO:0
cloud:RFBO:0
cloud:RFIO:0
cloud:IO:0
cloud:LEAK:0
cloud:C0:0
cloud:C1:0
cloud:C2:0
cloud:C3:0
cloud:C4:0
cloud:C5:0
cloud:C6:0
cloud:C7:0
cloud:R:0
cloud:ROFF:255
cloud:RON:0
cloud:T1:737
cloud:T2:766
cloud:T3:770
cloud:PH:796
cloud:T4:786
cloud:T5:0
cloud:T6:0
cloud:ORP:0
cloud:PHE:0
cloud:PAR:0
cloud:CEXP0:0
cloud:CEXP1:0
cloud:CEXP2:0
cloud:CEXP3:0
cloud:CEXP4:0
cloud:CEXP5:0
cloud:CEXP6:0
cloud:CEXP7:0
cloud:WL1:101
cloud:SAL:339
cloud:WL1:102
cloud:WL1:101
cloud:WL1:102
cloud:WL1:103
cloud:WL1:100
cloud:WL2:73
cloud:SAL:340
cloud:WL1:101
cloud:WL2:72
cloud:SAL:339
cloud:WL1:104
cloud:WL2:71
cloud:WL1:101
cloud:WL2:72
cloud:WL2:71
cloud:WL1:100
cloud:WL2:72
cloud:SAL:340
cloud:WL1:103
cloud:SAL:339
cloud:WL1:101
