Jebao/Speedwave Cable Attachment
PostPosted: Sat Feb 10, 2018 11:39 am
This is probably a stupid question, but Is the jebao factory controller still needed or does this cable take the place of it completely?
thanks.
PostPosted: Mon Feb 12, 2018 7:28 am
It depends on which version of the pump you are trying to use it with.
I have a DCP-10000 and have to use the controller that came with the pump. I'm fairly certain the cable works with the DC-XXXX versions. I'm not sure about the DCT-XXXX versions but I don't think so. These are just the return pumps and there are more in other threads about circulating pumps.
Check this thread - viewtopic.php?f=4&t=5887
Try to learn something about everything and everything about something... Thomas Huxley
210gal DT | 50gal sump/refug | Jebao DCP 10000 pump | RO 200-int skimmer | DIY built stand | DIY 160 led, 12 channel, 458 watt, on MakersLED 72" heatsink
Return to Standard
