Relay box repaired
Posted: Fri Feb 16, 2018 11:05 am
by bkc6868
Got it used knowing it was bad. I opened it up and fuse was blown. Also looks like there is a resistor completely melted off on the end of the small board opposite of where the little green led if mounted. Can it be repaired or will I need to buy a new one?
Re: Relay box repaired
Posted: Fri Feb 16, 2018 11:06 am
Can you post a photo?
