RA* shows disconnected
bkc6868
has ip address but isn't connecting to cloud. is there something in code that I have to enter username and password for it to connect ? uapp is connectiong but not updating. searches isn't turning up anything after a couple hrs
bkc6868
Re: RA* shows disconnected
Yes. When you generate your code using the web wizard, you have to enter the password and it is case sensitive.
bkc6868
Yeah I did that. I logged in with my old people first. Then realized I needed to change it. I then redid code with new PW add still isn't connecting to cloud. Web based uapp had no problems though
I'm pretty sure it is the password then.
Did you click encrypt and went all the way to generate and uploaded the code that was generated?
bkc6868
Can you post the code you are uploading?
It shows a blank password.
bkc6868
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit;
ReefAngel.FeedingModePortsE[1] = 0;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
ReefAngel.OverheatShutoffPortsE[1] = 0;
ReefAngel.LightsOnPortsE[1] = 0;
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.StandardHeater( T1_PROBE,Box1_Port2,760,770 );
ReefAngel.SingleATO( true,Box1_Port3,180,0 );
ReefAngel.StandardLights( Box1_Port4,10,0,22,0 );
ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
boolean buzzer=false;
if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff();
ReefAngel.Network.Cloud();
ReefAngel.ShowTouchInterface();
// RA_STRING1=U2FsdGVkX19l4rVch5Wsz3j92ZZ1yaCjltVKjB3fddY=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT11=Return
// RA_LABEL LABEL_PORT12=Heater
// RA_LABEL LABEL_PORT13=ATO
// RA_LABEL LABEL_PORT14=ReefBrite
// RA_LABEL LABEL_PORT15=Skimmer
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
That yields a blank password.
Make sure you type the password and hit encrypt and go all the way to the end of the wizard and click generate.
bkc6868
That's what I thought when I looked at it. That's why I asked about the code. So even though I don't have any attachments or expansions I can't click over them on the left? I have been clicking encrypt after every pw
bkc6868
I just went through it clicking next everytime and I'm still not seeing a pw
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
Doesn't make sense.
This is still a blank password.
Can you click encrypt after you type the password and send what it shows on the screen as encrypted password?
Then go to the end and generate. See if it matches.
If it does, I would try a different browser.
bkc6868
I just put PW in and got encrypt.... That string is what does in the box for forum password
Edit: string is different but starts out like it
bkc6868
Changed to come from IE .. Finally got connected.. Not sure why IE was having problems
Thanks Roberto
Thanks Roberto
