RA* shows disconnected
PostPosted: Sat Feb 24, 2018 6:37 pm
I just went through it clicking next everytime and I'm still not seeing a pw
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.StandardHeater( T1_PROBE,Box1_Port2,760,770 );
ReefAngel.SingleATO( true,Box1_Port3,180,0 );
ReefAngel.StandardLights( Box1_Port4,10,0,22,0 );
ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
boolean buzzer=false;
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX19l4rVch5Wsz3j92ZZ1yaCjltVKjB3fddY=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT11=Return
// RA_LABEL LABEL_PORT12=Heater
// RA_LABEL LABEL_PORT13=ATO
// RA_LABEL LABEL_PORT14=ReefBrite
// RA_LABEL LABEL_PORT15=Skimmer
PostPosted: Sat Feb 24, 2018 7:30 pm
Doesn't make sense.
This is still a blank password.
Can you click encrypt after you type the password and send what it shows on the screen as encrypted password?
Then go to the end and generate. See if it matches.
If it does, I would try a different browser.
PostPosted: Sat Feb 24, 2018 7:34 pm
I just put PW in and got encrypt.... That string is what does in the box for forum password
Edit: string is different but starts out like it
PostPosted: Sat Feb 24, 2018 7:59 pm
Changed to come from IE .. Finally got connected.. Not sure why IE was having problems
Thanks Roberto
Previous
Return to Standard
