Changing the dimming port signal
Posted: Tue Feb 27, 2018 7:50 am
by bkc6868
I have the RA star. Do I have to open the head unit to change the Jumpers? I need 0-5 own.
Re: Changing the dimming port signal
Posted: Tue Feb 27, 2018 8:54 am
Yes
Posted: Tue Feb 27, 2018 8:55 am
by bkc6868
Posted: Tue Feb 27, 2018 5:12 pm
by bkc6868
I see analog printed on board along with the channels but nothing about pwm and I don't see any jumper pieces
Posted: Tue Feb 27, 2018 5:13 pm
0-5V is right on the left side of where you saw analog.
Posted: Tue Feb 27, 2018 5:15 pm
by bkc6868
I saw that.. But the is no Jumpers
Posted: Tue Feb 27, 2018 5:19 pm
You are correct. They are not populated.
Not everyone changes signal types and you are the first one that mentioned it.
I'll instruct my contract manufacturer to install them on my next build.
You can get them on any electronic store or pull them from old motherboards.
Posted: Tue Feb 27, 2018 5:21 pm
by bkc6868
So should I jump every one of the 0-5v pins for pwm 0-5 volts?
Posted: Tue Feb 27, 2018 5:22 pm
Yeap.
Posted: Sat Mar 10, 2018 10:21 am
by bkc6868
Something happened and I'm no longer getting 5 volts from pins 1&2 and 5&6. 3&4 and 7&8 still work fine. I've checked and rechecked the Jumpers and settings on everything.
Posted: Sat Mar 10, 2018 10:35 am
There are only 4 channels and not 8. Which channels are you talking about?
Posted: Sat Mar 10, 2018 10:37 am
by bkc6868
Daylight 1 and actinic 1 the #2 channels are working still
Posted: Sat Mar 10, 2018 10:41 am
Do you have a multimeter?
Posted: Sat Mar 10, 2018 10:43 am
by bkc6868
Yes that's how I know they aren't putting out the 5 volts but the others are
Posted: Sat Mar 10, 2018 10:48 am
I'm assuming that the screen is showing 100% on those dimming channels on the RA* screen, right?
If so, The channels may have gotten damaged.
Can you check the voltages on these pads?
Actinic Channel
- actinic.png (168.96 KiB) Viewed 9392 times
Daylight Channel
- daylight.png (169.21 KiB) Viewed 9392 times
Posted: Sat Mar 10, 2018 10:49 am
by bkc6868
Yes I can later when I get home
