diy leds to RA*
PostPosted: Tue Feb 27, 2018 9:05 pm
by bkc6868
I connected my leds to the dimming port of the star but they will not respond to dimming. i checked and im getting 5 volts to the driver going in the dimming inputs. Any ideas
my code from the web wizard
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.FeedingModePortsE[1] = 0;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[1] = 0;
ReefAngel.LightsOnPortsE[1] = 0;
ReefAngel.StandardHeater( T1_PROBE,Box1_Port2,750,770 );
ReefAngel.SingleATO( true,Box1_Port3,120,0 );
ReefAngel.StandardLights( Box1_Port4,10,0,22,0 );
ReefAngel.Relay.DelayedOn( Box1_Port5,2 );
ReefAngel.StandardLights( Box1_Port6,6,0,12,0 );
ReefAngel.PWM.SetDaylight( PWMSlope( 13,0,21,0,5,70,100,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 10,0,21,0,10,100,100,0 ) );
ReefAngel.PWM.SetDaylight2( PWMSlope( 13,0,21,0,5,70,100,0 ) );
ReefAngel.PWM.SetActinic2( PWMSlope( 10,0,21,0,10,100,100,0 ) );
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX1+GGNHNdCwVcHPfkCqY6YdqeXBCpjNczyo=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=Return
// RA_LABEL LABEL_PORT12=Heater
// RA_LABEL LABEL_PORT13=ATO
// RA_LABEL LABEL_PORT14=ReefBrites
// RA_LABEL LABEL_PORT15=Skimmer
// RA_LABEL LABEL_PORT16=Scrubber light
// RA_LABEL LABEL_PORT17=Port 7
// RA_LABEL LABEL_PORT18=Port 8
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT23=Port 23
// RA_LABEL LABEL_PORT24=Port 24
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT28=Port 28
Re: diy leds to RA*
PostPosted: Wed Feb 28, 2018 12:40 am
If you are getting the correct dimming signal to the driver, it probably has nothing to do with the code.
It's got to be something on the driver or the wiring.
