Bus locks
PostPosted: Sun Mar 04, 2018 9:52 am
Last couple days my RA* has been getting bus locks. There are no expansions connected so I'm not sure where to start looking for the side of the problem
PostPosted: Sun Mar 04, 2018 10:33 pm
Is the touch screen responsive?
PostPosted: Mon Mar 05, 2018 5:05 am
No...I have to unplug and plug back in again
PostPosted: Mon Mar 05, 2018 11:40 am
When you power cycle, does it become responsive?
Are you the one that replaced the board? If so, can you double check the display flex cable you had to insert when replacing the board?
PostPosted: Mon Mar 05, 2018 11:43 am
Yeah it's good again after I unplug and plug back....I didn't replace the board this is a week old. I just put Jumpers for pwm 0-5 volts
PostPosted: Mon Mar 05, 2018 11:46 am
Ok, can you double check the display flex cable?
When you opened it, it may have been pulled and is having a bad connection now.
Return to Standard
