Dimming Kessil
PostPosted: Wed Mar 14, 2018 4:57 pm
by chachew
I have a RA+, will the dimming ports work with the Kessil or do I need an expansion module?
Re: Dimming Kessil
PostPosted: Wed Mar 14, 2018 5:02 pm
Yes, it will as long as your dimming signal is analog
Re: Dimming Kessil
PostPosted: Wed Mar 14, 2018 5:05 pm
by chachew
rimai wrote:Yes, it will as long as your dimming signal is analog
So I just need to buy the RA kessil cable? And connect it to one of the dimming ports?
Re: Dimming Kessil
PostPosted: Wed Mar 14, 2018 6:00 pm
Yes. But it uses both channels. One controls intensity and another color
Re: Dimming Kessil
PostPosted: Wed Mar 14, 2018 6:11 pm
by chachew
rimai wrote:Yes. But it uses both channels. One controls intensity and another color
Perfect. Exactly what I needed to know. So can you control the PWM as well? So to create a sunrise/sunset type effect?
Re: Dimming Kessil
PostPosted: Wed Mar 14, 2018 7:15 pm
Not with PWM signal. Kessil lights actually use analog signal.
But if you do have analog signal on the dimming channels, yes, you can control it to dim the lights.
Re: Dimming Kessil
PostPosted: Wed Mar 14, 2018 7:50 pm
by chachew
rimai wrote:Not with PWM signal. Kessil lights actually use analog signal.
Oh ok. So the kessils can dim from the RA+ dimming ports with the RA+ kessil cable?
Re: Dimming Kessil
PostPosted: Wed Mar 14, 2018 8:12 pm
Yes. Again, as long as your dimming signal is analog.
