Next question is on the RA+ thru the portal. I could have the system send email for problems ie alarm ext.
how do set this up now.
Is the old system now off line for me or is it still used?
thanks
RA+ to RA*
• Page 2 of 4 • 1, 2, 3, 4
riggeek
Still the same
When i try to cal the water level expansion it only show a value of 0.
Same when I try to call the salinity it shows 0. they both go thru the usb hub riggeek
I think i got this figure out the dimming expansion seems to cause the problem when plugged into the hub.
riggeek
Every seems to be working thru the Uapp.
But portal still shows Connection Status: Unreachable Address Is there still something to set up there? riggeek
I would use only uapp since it is cloud connected.
If you want to use the portal, you will need to setup port forwarding on your router Roberto.
Does the Uapp have a way to do the portal setting to forward the alarms to email?
Also the display seems to go to sleep and does not want to wake up is the some way to wake it up besides cycling power? riggeek
Just set up the alerts in the portal.
It will work. Your controller sends data to the portal every 5 minutes. That's what populates the charts and banners and also triggers the email alerts. This is independent of the portal being able to connect to your controller or not. Traffic only gets blocked by your router when the portal tries to access the controller, but it does allow for your controller to send data to portal just fine. Roberto.
When I set the alerts in the portal. it acts like it is going to take them, but they never show up in the list. Any Ideas?
riggeek
I was able to add one.
Do you see the one I created for you? Can you try again and make sure you don't use < or > signs anywhere in the name or description. It may get confused. If it still doesn't work, try another browser. Roberto.
