Did you do something from your end? It just started working i can see the alarms now.
Tried to add one and now it is not letting me see them again
RA+ to RA*
• Page 4 of 4 • 1, 2, 3, 4
riggeek
Yes.
I deleted the extra space you placed on one of the alert names. I think for some reason it doesn't like the space at the end of the alert names. The last character cannot be a space. I edited the name on the one you just entered again. Can you see if you can get them to show up now? Roberto.
They are showing up now.
Am I ok to try and edit and add now? riggeek
just make sure you don't add a space at the end of the name as you did before.
It did it again. I got to add the alarm one. then tried to add one more for low temp and did it again. I do not think I had a space there. Could it be the < or > signs?
Maybe delete all of them for me and I will start again. riggeek
It's putting a space at the end of the name somehow.
I removed it again. Roberto.
Getting bus lock errors again. I have had 3 in the last 24 hours.
I have checked all the usb connectors, I have remove all the expansion modules, I have remove the USB expansion hub. It is just the RA*, and the relay box. the relay box is plugged strait into the RA* I also seen it do a random reboot on its own. Any thoughts? riggeek
Ok, so there is some noise coming in from somewhere.
I did get your PM. Let me send you a radio and another usb cable for you to try. Roberto.
