Does anyone have any idea why the uapp faults out when I try to swap pump modes?
I programmed it on lagoon and can not change it. I just used the wizard to programming.
When I try to change it it just times out, and does not change.
Any idea?
thanks
Wave pump mode new RA*
• Page 1 of 2 • 1, 2
riggeek
did you hard code the mode? or did you program the controller to use the internal memory?
Sent from my XT1585 using Tapatalk |
though I selected internal memory. I can change light time, and levels, kalk dosing, and other things. I just can not change the pumps.
riggeek
Do we still think it is programing
riggeek
post your code. Sent from my XT1585 using Tapatalk |
#include <ReefAngel_Features.h> #include <Globals.h> #include <RA_TS.h> #include <RA_TouchLCD.h> #include <RA_TFT.h> #include <RA_TS.h> #include <Font.h> #include <RA_Wifi.h> #include <RA_Wiznet5100.h> #include <SD.h> #include <SPI.h> #include <Ethernet.h> #include <EthernetDHCP.h> #include <PubSubClient.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_ATO.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <RA_CustomLabels.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <PAR.h> #include <DCPump.h> #include <ReefAngel.h> #include <SoftwareSerial.h> ////// Place global variable code below here ////// Place global variable code above here void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller ReefAngel.Star(); // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = 0; ReefAngel.FeedingModePortsE[0] = 0; ReefAngel.FeedingModePortsE[1] = 0; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = 0; ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit; ReefAngel.WaterChangePortsE[1] = 0; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = 0; ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port5Bit; ReefAngel.OverheatShutoffPortsE[1] = 0; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = 0; ReefAngel.LightsOnPortsE[0] = Port3Bit | Port5Bit; ReefAngel.LightsOnPortsE[1] = 0; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 790 ); // Feeeding and Water Change mode speed ReefAngel.DCPump.FeedingSpeed=0; ReefAngel.DCPump.WaterChangeSpeed=0; // Ports that are always on ReefAngel.Relay.On( Box1_Port6 ); ReefAngel.Relay.On( Box1_Port7 ); ReefAngel.Relay.On( Box1_Port8 ); ////// Place additional initialization code below here ////// Place additional initialization code above here } void loop() { ReefAngel.SingleATOLow( Box1_Port1 ); ReefAngel.DosingPumpRepeat1( Box1_Port2 ); ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Box1_Port5 ) ); ReefAngel.StandardHeater1( Box1_Port4 ); ReefAngel.StandardLights( Box1_Port5 ); ReefAngel.PWM.DaylightPWMSlope(); ReefAngel.PWM.ActinicPWMSlope(); ReefAngel.DCPump.UseMemory = false; ReefAngel.DCPump.SetMode( Lagoon,50,10 ); ReefAngel.DCPump.DaylightChannel = None; ReefAngel.DCPump.ActinicChannel = None; ReefAngel.DCPump.Daylight2Channel = Sync; ReefAngel.DCPump.Actinic2Channel = AntiSync; boolean buzzer=false; if ( ReefAngel.isATOTimeOut() ) buzzer=true; if ( ReefAngel.isOverheat() ) buzzer=true; if ( ReefAngel.isBusLock() ) buzzer=true; if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff(); ////// Place your custom code below here ////// Place your custom code above here ReefAngel.Network.Cloud(); // This should always be the last line ReefAngel.ShowTouchInterface(); } // RA_STRING1=U2FsdGVkX19aL/7SAbcu/cSNYLbA2zgwzRGnL+NV8E0= // RA_STRING2=null // RA_STRING3=null // RA_LABEL LABEL_ACTINIC=Actinic // RA_LABEL LABEL_ACTINIC2=Actinic 2 // RA_LABEL LABEL_DAYLIGHT=Daylight // RA_LABEL LABEL_DAYLIGHT2=Daylight 2 // RA_LABEL LABEL_PORT11=ATO // RA_LABEL LABEL_PORT12=Kalk // RA_LABEL LABEL_PORT13=Rlight // RA_LABEL LABEL_PORT14=Heater // RA_LABEL LABEL_PORT15=LED // RA_LABEL LABEL_PORT16=Rpump // RA_LABEL LABEL_PORT17=Skim // RA_LABEL LABEL_PORT18=Wave // RA_LABEL LABEL_PORT21=Port 21 // RA_LABEL LABEL_PORT22=Port 22 // RA_LABEL LABEL_PORT23=Port 23 // RA_LABEL LABEL_PORT24=Port 24 // RA_LABEL LABEL_PORT25=Port 25 // RA_LABEL LABEL_PORT26=Port 26 // RA_LABEL LABEL_PORT27=Port 27 // RA_LABEL LABEL_PORT28=Port 28 riggeek
This line says it all:
Your DC Pump control is hard coded and will not use the internal memory at all. It will always use this:
So, if you want to use the internal memory and control it remotely, you will need to remove the SetMode(Lagoon) line and change the memory line to this:
Then the controller will always use what values are in Internal Memory. Which means you should set them to a sensible value first, then change the UseMemory line and remove the SetMode line. |
thanks
still a working in progress at this point. riggeek
it seems like they always are... I know mine is. Sent from my XT1585 using Tapatalk |
Still not working right
here is the code again #include <Salinity.h> #include <ReefAngel_Features.h> #include <Globals.h> #include <RA_TS.h> #include <RA_TouchLCD.h> #include <RA_TFT.h> #include <RA_TS.h> #include <Font.h> #include <RA_Wifi.h> #include <RA_Wiznet5100.h> #include <SD.h> #include <SPI.h> #include <Ethernet.h> #include <EthernetDHCP.h> #include <PubSubClient.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_ATO.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <RA_CustomLabels.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <PAR.h> #include <DCPump.h> #include <ReefAngel.h> #include <SoftwareSerial.h> ////// Place global variable code below here ////// Place global variable code above here void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller ReefAngel.Star(); ReefAngel.AddWaterLevelExpansion(); // Water Level Expansion Module // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = 0; ReefAngel.FeedingModePortsE[0] = Port2Bit | Port7Bit | Port8Bit; ReefAngel.FeedingModePortsE[1] = 0; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = 0; ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port8Bit; ReefAngel.WaterChangePortsE[1] = 0; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = 0; ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port5Bit; ReefAngel.OverheatShutoffPortsE[1] = 0; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = 0; ReefAngel.LightsOnPortsE[0] = Port3Bit | Port5Bit; ReefAngel.LightsOnPortsE[1] = 0; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 790 ); // Feeeding and Water Change mode speed ReefAngel.DCPump.FeedingSpeed=0; ReefAngel.DCPump.WaterChangeSpeed=0; // Ports that are always on ReefAngel.Relay.On( Box1_Port6 ); ReefAngel.Relay.On( Box1_Port7 ); ReefAngel.Relay.On( Box1_Port8 ); ////// Place additional initialization code below here ////// Place additional initialization code above here } void loop() { ReefAngel.SingleATOLow( Box1_Port1 ); ReefAngel.DosingPumpRepeat1( Box1_Port2 ); ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Box1_Port5 ) ); ReefAngel.StandardHeater1( Box1_Port4 ); ReefAngel.StandardLights( Box1_Port5 ); ReefAngel.PWM.DaylightPWMParabola(); ReefAngel.PWM.ActinicPWMParabola(); ReefAngel.DCPump.UseMemory = true; ReefAngel.DCPump.SetMode( Lagoon,50,10 ); ReefAngel.DCPump.DaylightChannel = None; ReefAngel.DCPump.ActinicChannel = None; ReefAngel.DCPump.Daylight2Channel = Sync; ReefAngel.DCPump.Actinic2Channel = AntiSync; boolean buzzer=false; if ( ReefAngel.isATOTimeOut() ) buzzer=true; if ( ReefAngel.isOverheat() ) buzzer=true; if ( ReefAngel.isBusLock() ) buzzer=true; if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff(); ////// Place your custom code below here ////// Place your custom code above here ReefAngel.Network.Cloud(); // This should always be the last line ReefAngel.ShowTouchInterface(); } // RA_STRING1=U2FsdGVkX1+A7n1/gG5uO89kqJa/wC0XzX2jNCiREAY= // RA_STRING2=null // RA_STRING3=null // RA_LABEL LABEL_ACTINIC=Actinic // RA_LABEL LABEL_ACTINIC2=wave 2 // RA_LABEL LABEL_DAYLIGHT=Daylight // RA_LABEL LABEL_DAYLIGHT2=wave 1 // RA_LABEL LABEL_PORT11=ATO // RA_LABEL LABEL_PORT12=Kalk // RA_LABEL LABEL_PORT13=Rlight // RA_LABEL LABEL_PORT14=Heater // RA_LABEL LABEL_PORT15=LED // RA_LABEL LABEL_PORT16=Rpump // RA_LABEL LABEL_PORT17=Skimmer // RA_LABEL LABEL_PORT18=Wave // RA_LABEL LABEL_PORT21=Port 21 // RA_LABEL LABEL_PORT22=Port 22 // RA_LABEL LABEL_PORT23=Port 23 // RA_LABEL LABEL_PORT24=Port 24 // RA_LABEL LABEL_PORT25=Port 25 // RA_LABEL LABEL_PORT26=Port 26 // RA_LABEL LABEL_PORT27=Port 27 // RA_LABEL LABEL_PORT28=Port 28 riggeek
