Page 1 of 2
Wave pump mode new RA*
PostPosted: Fri Apr 20, 2018 11:02 am
by riggeek
Does anyone have any idea why the uapp faults out when I try to swap pump modes?
I programmed it on lagoon and can not change it. I just used the wizard to programming.
When I try to change it it just times out, and does not change.
Any idea?
thanks
Re: Wave pump mode new RA*
PostPosted: Fri Apr 20, 2018 6:14 pm
did you hard code the mode? or did you program the controller to use the internal memory?
PostPosted: Sat Apr 21, 2018 3:40 am
by riggeek
though I selected internal memory. I can change light time, and levels, kalk dosing, and other things. I just can not change the pumps.
PostPosted: Tue Apr 24, 2018 1:54 pm
by riggeek
Do we still think it is programing
PostPosted: Tue Apr 24, 2018 3:58 pm
riggeek wrote:Do we still think it is programing
post your code.
PostPosted: Sat Apr 28, 2018 6:01 am
by riggeek
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.SingleATOLow( Box1_Port1 );
ReefAngel.DosingPumpRepeat1( Box1_Port2 );
ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Box1_Port5 ) );
ReefAngel.StandardHeater1( Box1_Port4 );
ReefAngel.StandardLights( Box1_Port5 );
ReefAngel.DCPump.SetMode( Lagoon,50,10 );
ReefAngel.DCPump.Daylight2Channel = Sync;
ReefAngel.DCPump.Actinic2Channel = AntiSync;
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
if ( ReefAngel.isBusLock() ) buzzer=true;
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX19aL/7SAbcu/cSNYLbA2zgwzRGnL+NV8E0=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=ATO
// RA_LABEL LABEL_PORT12=Kalk
// RA_LABEL LABEL_PORT13=Rlight
// RA_LABEL LABEL_PORT14=Heater
// RA_LABEL LABEL_PORT15=LED
// RA_LABEL LABEL_PORT16=Rpump
// RA_LABEL LABEL_PORT17=Skim
// RA_LABEL LABEL_PORT18=Wave
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT23=Port 23
// RA_LABEL LABEL_PORT24=Port 24
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT28=Port 28
PostPosted: Sat Apr 28, 2018 2:13 pm
This line says it all:
Your DC Pump control is hard coded and will not use the internal memory at all. It will always use this:
So, if you want to use the internal memory and control it remotely, you will need to remove the SetMode(Lagoon) line and change the memory line to this:
Then the controller will always use what values are in Internal Memory. Which means you should set them to a sensible value first, then change the UseMemory line and remove the SetMode line.
PostPosted: Sun Apr 29, 2018 7:44 am
by riggeek
thanks
still a working in progress at this point.
PostPosted: Sun Apr 29, 2018 11:30 am
riggeek wrote:thanks
it seems like they always are...
I know mine is.
PostPosted: Tue May 01, 2018 11:37 am
by riggeek
Still not working right
here is the code again
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port8Bit;
// RA_STRING1=U2FsdGVkX1+A7n1/gG5uO89kqJa/wC0XzX2jNCiREAY=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC2=wave 2
// RA_LABEL LABEL_DAYLIGHT2=wave 1
// RA_LABEL LABEL_PORT17=Skimmer
