I want to change my Feeding Mode setup to where I use it for coral feeding instead of fish feeding. During Feeding Mode, I want to shut down my skimmer, UV pump, and UV bulb for maybe 1.25 hours. I don't see an easy way to define the length of Feeding Mode, so my thought was to manage the time-off for these devices by using DelayedOn (the skimmer is already using DelayedOn). Adding DelayedOn to the UV pump is simple enough, but I've already defined my UV bulb as a StandardHeater. I don't know if I can also define it as DelayedOn. I can use if/then statements, something like:
if ( ReefAngel.Params.Temp [T2_PROBE ] >= 794 ) ReefAngel.Relay.Off( Port7 );
if ( ReefAngel.Params.Temp [T2_PROBE ] <= 788 ) ReefAngel.Relay.On( Port7 );
- 1. Manipulate the time expended for Feeding Mode.
2. Use both StandardHeater and DelayedOn for the relay/port that runs my UV bulb.
3. Use if/then statements for my UV bulb.
I'm just a little nervous because running the UV bulb without water circulating would be a BAD thing. Any help would be greatly appreciated.
