problem rele raffreddamento
PostPosted: Wed Aug 29, 2018 11:34 am
salve,
ho un problema con la funzione del raffreddamento.
metto che si attiva a 25.8 e si disattiva a 25. pero si stacca a 25.8 non so come risolvere grazie di seguito il codice:
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port5Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 294 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( T1_PROBE,Port1,220,252 );
ReefAngel.StandardATO( Port2,10 );
ReefAngel.Relay.DelayedOn( Port3,2 );
ReefAngel.PHControl( Port4,695,646 );
ReefAngel.StandardFan( T1_PROBE,Port8,258,255 );
ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.Portal( "ROBBYMAN86" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC=Actinic
// RA_LABEL LABEL_DAYLIGHT=Daylight
PostPosted: Wed Aug 29, 2018 12:28 pm
He said that have an issues with fan function although he programmed on 25,5 and off 25,0, once the Temperature go down 25,5 the fan stop . The fan start at 25,6
Inviato dal mio iPhone utilizzando Tapatalk
PostPosted: Thu Aug 30, 2018 10:56 pm
no one who can help me? I'm also trying to send a message to rimai, but I'm not authorized
PostPosted: Thu Aug 30, 2018 11:46 pm
I think it should be 255,258.
Did you use the wizard and entered the correct values?
PostPosted: Thu Aug 30, 2018 11:49 pm
rimai wrote:I think it should be 255,258.
thanks for the answer, I used the wizard and on turned on I put 25.8 and off at 25.5
PostPosted: Thu Aug 30, 2018 11:53 pm
Here this pictureImage
Inviato dal mio CLT-L09 utilizzando Tapatalk
PostPosted: Sat Sep 01, 2018 4:28 am
PostPosted: Sat Sep 01, 2018 1:34 pm
The fan will turn on at 25.8 and continue to run until temperature lowers to 25.5. it will not turn on again until the temperature increases to 25.8 again. So there can be a 0.3 degree fluctuation of temperature.
PostPosted: Sat Sep 01, 2018 2:28 pm
binder wrote:The fan will turn on at 25.8 and continue to run until temperature lowers to 25.5. it will not turn on again until the temperature increases to 25.8 again. So there can be a 0.3 degree fluctuation of temperature.
So it should be, instead at 25.8 it goes out
PostPosted: Mon Sep 03, 2018 1:30 pm
hi, problem solved thanks to sebimme,
the problem was in the code that was created by the online widard, I redid the code with the arduino program and it went well,
but there is a problem I do not download the labels from the portal
Next
Return to Standard
Users browsing this forum: No registered users and 6 guests
