problem rele raffreddamento
sebimme
Re: problem rele raffreddamento
Post by sebimme »
Hi guys, please Roberto look at the code generatated with webwizard because if you program with it the standardfan function don’t work fine, while if you program with wizard inside arduino program it work good...
Inviato dal mio iPhone utilizzando Tapatalk
I'll look into it.
sebimme
Post by sebimme »
Any update
On what?
sebimme
Post by sebimme »
You said ...I’ll look into it....
Do you find the problem?
No. I'll look into it.
Fixed
sebimme
Post by sebimme »
Ciao Roberto
Same error for ph controlled port continuously on off, like the chiller
Can you post the code you got?
sebimme
Post by sebimme »
Is the same of the first post by ROBBYMAN86
Ah, ok. The values have to be inverted position too.
No. The code was correct.
Are you using it to increase or decrease pH?
Make sure the values are in the correct order.
sebimme
Post by sebimme »
To decrease ph, how you can see from the code the values are right but the port can’t control properly because the on off cicle are inconsistent with values
You are using the wrong function...
pH Control:
This function turns on/off at specific pH readings. The device that uses this function must increase pH. Example of device that may use this function is a Kalk based Doser.
CO2 Control:
This function turns on/off at specific pH readings. The device that uses this function must lower pH. Example of device that may use this function is a calcium reactor.
