Web Wizard Problem?
PostPosted: Tue Nov 27, 2018 8:19 pm
I'm trying to upload new code using the Web Wizard and I keep getting this error. Everything was working fine last week. Am I doing something wrong here?
Error message:
Compiling code for RA_PLUS board
Number of Relay Expansion Modules: 1
Dimming Expansion Module
Dimming Signal
Wifi Attachment
DC Pump Control (Jebao/Tunze)
2014 Main Screen
Extra Font - Medium Size (8x8 pixels)
Multi Channel Water Level Expansion Module
RANet framework
Standard Menu
Standard Menu
Standard Menu
Standard Menu
In file included from firmware.ino:2:0:
D:\Arduino\libraries\Globals/Globals.h:367:8: error: 'SoftwareSerial' does not name a type
static SoftwareSerial RANetSerial(RANetRXPin,RANetTXPin);
exit status 1
Progress: 41.38%
Your code has some errors and couldn't be compiled.
Please fix the errors above and try again.
My code:
#define FONT_8x8
#define FONT_8x16
// Define relay box ports
// Relay Box #1
#define  FugeLight      Box0_Port1
#define  Skimmer        Box0_Port2
#define  SumpLight      Box0_Port3
#define  NA2            Box0_Port4
#define  ReturnPump     Box0_Port5
#define  Heater         Box0_Port6
#define  CalDoser       Box0_Port7
#define  AlkDoser       Box0_Port8
// Relay Box #2
#define  PowerHead1     Box1_Port1
#define  ActinicLED     Box1_Port2
#define  PowerHead2     Box1_Port3
#define  Kessil_A       Box1_Port4
#define  Kessil_B       Box1_Port5
#define  Kessil_C       Box1_Port6
#define  NA3            Box1_Port7
#define  Fans           Box1_Port8
void setup() {
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
    ReefAngel.AddRANet();  // RANet Add-On Module
    ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPortsE[0] = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
    InternalMemory.OverheatTemp_write(828);
    ReefAngel.Relay.On(Skimmer);
    ReefAngel.Relay.On(ReturnPump);
    ReefAngel.Relay.On(PowerHead1);
    ReefAngel.Relay.On(PowerHead2);
    // Process IO Functions
    // processIoModule();
void loop() {
    ReefAngel.Relay.DelayedOn(Skimmer, 1);
    ReefAngel.ActinicLights(ActinicLED);
    ReefAngel.DayLights(Kessil_A);
    ReefAngel.DayLights(Kessil_B);
    ReefAngel.DayLights(Kessil_C);
    ReefAngel.StandardHeater1(Heater);
    // Set up dosing pumps
    ReefAngel.DosingPumpRepeat1(CalDoser);
    ReefAngel.DosingPumpRepeat2(AlkDoser);
    if (daylightsOn()) {
        // Always run the fans when the Daylights are on to vent the canopy
        ReefAngel.Relay.On(Fans);
        ReefAngel.Relay.Off(FugeLight);
        ReefAngel.PWM.SetChannel(1,0);
        ReefAngel.PWM.SetChannel(2,0);
        ReefAngel.PWM.SetChannel(3,0);
    } else {
        ReefAngel.StandardFan(Fans);
        ReefAngel.Relay.On(FugeLight);
        ReefAngel.PWM.SetChannel(1,MoonPhase());
        ReefAngel.PWM.SetChannel(2,MoonPhase());
        ReefAngel.PWM.SetChannel(3,MoonPhase());
    ReefAngel.DCPump.ExpansionChannel[5] = Sync;
    ReefAngel.DCPump.ExpansionChannel[4] = AntiSync;
    if (ReefAngel.DisplayedMenu != FEEDING_MODE || ReefAngel.DisplayedMenu != WATERCHANGE_MODE) {
        if (!daylightsOn()) {   // Night mode - lower the flow
            ReefAngel.DCPump.SetMode(ReefCrest,45,10);
        else if (now()%2*SECS_PER_HOUR<5*60) {  // Run NutrientTransport mode every two hours for 5 minutes
            ReefAngel.DCPump.SetMode(NutrientTransport,90,30);
        else {
    ReefAngel.Portal("Piper");
// * Utility Functions
boolean lightsAreOn () {
  return actinicsOn() || daylightsOn();
boolean actinicsOn () {
  return ReefAngel.Relay.Status(ActinicLED);
boolean daylightsOn () {
  return ReefAngel.Relay.Status(Kessil_A);
PostPosted: Tue Nov 27, 2018 8:30 pm
Humm. I think it is a bug from the last merge I did a few days ago.
Let me check it out later
PostPosted: Tue Nov 27, 2018 8:49 pm
Thanks, Roberto!
PostPosted: Thu Nov 29, 2018 11:59 am
Give it a shot now.
PostPosted: Thu Nov 29, 2018 4:28 pm
Thanks, Roberto. It's compiling fine now.
Return to Standard
Users browsing this forum: No registered users and 7 guests
