Timeout communicating with programmer
stolat01
Post by stolat01 »
I'm unable to upload after using the wizard. Why would I get this message below? Assistance appreciated.
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 24,056 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -V -Uflash:w:C:\Users\Frank\AppData\Local\Temp\build3387721959718533521.tmp\sketch_dec20c.cpp.hex:i
Using Port : \\.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
Re: Timeout communicating with programmer
Are you sure com4 is the port you have your RA+ connected to?
stolat01
Post by stolat01 »
I am sure it is COM4. I confirmed it in the Device Manager, removed the USB, readded it. All this occurred in Windows 10.
Weird thing, I separately went to my Mac and tried the same upload. The Mac laptop allows me to keep the controller powered through its serial port while the TTL cable is plugged into the MAC. It failed the same way, initially. But while my controller was powered by the serial cable anyways I got into WAG mode and started modifying TOOL settings and uploading to see if something else worked. When I changed the PROGRAMMER setting to AVR ISP, from AVR ISP mkII, the upload worked. However, repeating this same setting change under Windows did not work. I have to copy my code to the MAC now. Does this offer you any clues? It appears that the controller is not communicating properly through the TTL cable ONLY when connected on my Windows PC, but it is communicating in MACOS with TTL cable AND power supplied by Serial cable.
RA should not get power through the usb-ttl cable.
How did you get power?
stolat01
Post by stolat01 »
via Windows the USB-ttl cable is my only connection. I take the controller offline when I go to my PC.
If RA is not powered, it can't be programmed.
It should not get power from usb-ttl cable alone either, regardless of OS.
Are you sure you are connecting it right?
stolat01
Post by stolat01 »
Got it figured out. A powered serial connection is still required when uploading code.
