Convert 0-10v to 5v pwm
Posted: Tue Feb 26, 2019 10:38 am
by topjimmy
Any way to use the dimming ports for the actinic on a led driver that takes 3.3 - 5v?
If not, then if I use the ato ports will I be able to dim the channels via the app?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Re: Convert 0-10v to 5v pwm
Posted: Tue Feb 26, 2019 10:43 am
You will have to open the relay box to desolder some components.
The ato port won't allow you to use the app to change the %.
You can get a dimming expansion module which has jumpers to change the signal or you can get the RA*, which also has jumpers.
Posted: Tue Feb 26, 2019 10:58 am
by topjimmy
I was hoping that there was a way to step it down before the driver.
Posted: Tue Feb 26, 2019 11:02 am
If you use a resistor divider, it may work depending on your driver.
