What are you all using for powerheads?
Re: What are you all using for powerheads?
SouthernReefer wrote:
binder wrote:I believe so. The only downside, I think, is that it only uses 4 of the 8 wires. This will allow you to only use 2 of the 4 channels. it's not a big deal initially, unless you plan to use all 4 of the pwm channels.
Good as I've got it on order. I'll be running 2 of the reef octopus octopulse 2s that's the only item I'm looking to use 0 to 10 v for. If I decide to add a new return pump with o 0 to 10 I'll have to build my own cable then.
you will have to look at what wires are used in the network connector to tell what pwm channels are being used. I have that same cable but not handy, so I can't tell you. the best way is to plug both cables in and have the pwm set to zero. then manually change 1 channel at a time and see what happens. (of course, you probably already knew that but I still felt like sharing)
SouthernReefer
Post by SouthernReefer »
Actually I didn't. This is my first controller and first time with 0 to 10 control, but I'm a tech guy so very inclined, but still would of taken a bit of research, so that saves me some time. I appreciate it!!
SouthernReefer wrote:Actually I didn't. This is my first controller and first time with 0 to 10 control, but I'm a tech guy so very inclined, but still would of taken a bit of research, so that saves me some time. I appreciate it!!
anytime. feel free to ask all questions you want or even PM me. I'll help as best as I can.
SouthernReefer
Appreciate it! Just started remodeling the room the new tank is going in, so won't be long before im wiring it all up and get it coded. Already doscovt about 3 more modules I "need" LOL
