PH probe calibrated at factory, or does it need calibration?
Posted: Tue Oct 06, 2020 9:43 am
Tanks getting wet this weekend. Do i need to do the PH probe calibration task or is it good from factory?
https://forum.reefangel.com/
Probably will want to calibrate it. It won't hurt anything if you don't, it just won't be accurate.SouthernReefer wrote:Tanks getting wet this weekend. Do i need to do the PH probe calibration task or is it good from factory?
I calibrated it, and it's reading at 8.2 to 8.3 we're in good shape.binder wrote:Probably will want to calibrate it. It won't hurt anything if you don't, it just won't be accurate.SouthernReefer wrote:Tanks getting wet this weekend. Do i need to do the PH probe calibration task or is it good from factory?
Sent from my Pixel 2 using Tapatalk
