I ordered this http://www.dealextreme.com/p/universal- ... lack-81053
looks like it can work. will post results when I get it.
Mounting Bracket
Re: Mounting Bracket
Nice finding
Let us know how it looks and if you can post a picture, it would be awesome!!
It took some time to get this holder. Then I went for a short vacation... Anyway, I'm ready to share some pictures.
There are two raised parts at the bottom of the holder that prevent controller from mounting flat (circled with red).
To be cont...Re: Mounting Bracket
Those bumps must go:
Now it fits better:
To be cont...
Mounting to the door using double sided tape.
You have to remove bumps for better fit. I also removed one padding on each side of the mount.
But it is not half bad for $5 delivered.
You can try to use suction mount, but I did not see any good from it in my application. The only way I can think of is to mount it to the side of tank or sump, but I want to keep controller as far from water as possible.
