minimum PC requirements
jgriffith
Post by jgriffith »
To download all the files and apps? RAGen and Installer, etc.
Re: minimum PC requirements
I think all you need is .NET 4
jgriffith
Post by jgriffith »
So I guess that means windows XP or later?
Yeah
RAGen has all the additional requirements built into it. You just need to run XP or later (like what was already mentioned).
jgriffith
Post by jgriffith »
Thanks, I use a mac and have the opportunity to buy an older pc laptop for real cheap, it runs XP so it should be good to go. It seems that there are a lot more options with PCs as far as coding the controller.
jgriffith wrote:Thanks, I use a mac and have the opportunity to buy an older pc laptop for real cheap, it runs XP so it should be good to go. It seems that there are a lot more options with PCs as far as coding the controller.
Most everybody uses a PC on here. I personally run Linux (Ubuntu) on my main computer, yet I wrote RAGen. I've actually been wanting to make RAGen cross platform but just have not had the time to do it yet. We shall see what all transpires.
