web chart and relay activity together
Related to the Portal
OceanWolf
Post by OceanWolf »
Is there a way to see Web chart and Relay activity together?
I want to see the effect of the relay activity on the readings.
Specifically I am trying to see what happens to the hood temperature when the relay comes on.
Onur
Re: web chart and relay activity together
You can create a webchart in another window.
http://forum.reefangel.com/viewtopic.php?f=20&t=771
If you want in the same chart, you would have to check on how to change the jquery settings of the chart engine to accomplish that.
