Portal Issues
Related to the Portal
PostPosted: Wed Dec 06, 2017 11:40 pm
That's not correct.
Make sure to connect at 57600 baud rate
When you are connected, type "$$$". It will return with a prompt. type "get e"
PostPosted: Thu Dec 07, 2017 2:44 pm
rimai wrote:That's not correct.
PostPosted: Thu Dec 07, 2017 4:07 pm
It did not update your host entry.
It should show
HOST=104.36.18.155
So, connect again and send command "set i h 104.36.18.155"
Then send "save" and send "reboot"
Just to make sure it updated, grab the "get e" again and see if it updated.
If it did, you are all good.
Previous
Return to Portal
