Our DDNS service
Related to the Portal
PostPosted: Sat Jun 11, 2016 11:41 am
hmmm if I simply use astralmind-reef.myreefangel.com, it attempts to connect directly to my router asking for its credentials. I have to add the ":2000" for it to bounce to my reef angel (and from there on it seems fine). Did I miss something ?
PostPosted: Sat Jun 11, 2016 11:46 am
astralmind wrote:hmmm if I simply use astralmind-reef.myreefangel.com, it attempts to connect directly to my router asking for its credentials. I have to add the ":2000" for it to bounce to my reef angel (and from there on it seems fine). Did I miss something ?
Nope, that is correct. The DDNS service just points a domain name to your home network (ip address). you still need the port to get to the reef angel.
PostPosted: Sat Jun 11, 2016 6:04 pm
Perfect, thanks! Awesome job on the android app btw, had not used it in 3 years, it evolved nicely
PostPosted: Sat Jun 11, 2016 6:40 pm
PostPosted: Sat Feb 24, 2018 5:34 am
I've been having trouble with this for several days now. I'm unable to get a connection using myreefangel.com through Curt's app. Error 13 failed to connect, but it shows the wrong IP address. My no-ip address works fine, as does the portal. Has the myreefangel.com stopped updating for me?
PostPosted: Sat Feb 24, 2018 7:58 am
cosmith71 wrote:I've been having trouble with this for several days now. I'm unable to get a connection using myreefangel.com through Curt's app. Error 13 failed to connect, but it shows the wrong IP address. My no-ip address works fine, as does the portal. Has the myreefangel.com stopped updating for me?
I thought I saw something about the service not being available anymore but I don't recall. I would have to search more for it. If it is stopped, I still have my domain available for use. It's not as easy as the RA one but it works and is free.
PostPosted: Sat Feb 24, 2018 8:15 am
yes, the RA ddns was brought down. see this post in the thread.
viewtopic.php?p=56452#p56452
He doesn't elaborate more but it's down.
PostPosted: Sat Feb 24, 2018 9:17 am
I need to figure out how to do it on a Linux system, which is what our new server is.
Until then, it is not updating :(
PostPosted: Sat Feb 24, 2018 10:30 am
rimai wrote:I need to figure out how to do it on a Linux system, which is what our new server is.
just a quick search yielded this
https://yingtongli.me/blog/2017/04/18/dynamic-dns.html
and this
http://andrwe.org/linux/own-ddns
now, i don’t know how well this would work for you but it can give you an idea of how to update the records when you get the values/ip address.
PostPosted: Sat Feb 24, 2018 10:49 am
That would explain it! I'm up and running on no-ip, so it's not a big deal right now.
PreviousNext
Return to Portal
