Setting up RA* for Portal
Related to the Portal
PostPosted: Wed Jul 11, 2018 9:02 pm
Is there something I have to do to set the Portal up to recognize my RA*? It was previously set up for RA+ and is showing unreachable address as I disconnected the Wifi attachment from the RA+. My RA* is showing Cloud Connection: Connected and I've been able to upload code remotely through the wizard.
Thanks ~
PostPosted: Wed Jul 11, 2018 9:41 pm
Use the uapp instead of the portal:
uapp
Just make sure that when when creating a profile, you just set the cloud username and password and leave the ip and port blank.
PostPosted: Thu Jul 12, 2018 7:04 pm
Thanks Roberto!
PostPosted: Sun Jul 15, 2018 1:37 pm
I'm not sure where to go next. My uapp shows connected to the cloud through a browser, but I'm not getting any data - Temp; Relay Status, etc.
I'm also trying to use the iPhone uapp and it the cloud server is disconnected. I've tried updating the password multiple times and the UserID and PW is blank.
My RA* unit is showing a successful connection to the cloud. Thoughts?
PostPosted: Sun Jul 15, 2018 2:34 pm
Uapp for iPhone is not updated. Use the web browser version on Safari and it should work the same way.
If you browse http://ipaddress:2000/r99 what do you get?
Get the ip address on the status page of the controller.
PostPosted: Sun Jul 15, 2018 3:52 pm
rimai wrote:Uapp for iPhone is not updated. Use the web browser version on Safari and it should work the same way.
I'm getting this from my desktop:
"ipaddress’s server IP address could not be found."
PostPosted: Sun Jul 15, 2018 4:55 pm
Well, you need to replace with your own IP address. That's why I said to find the IP address in the status page of the controller.
PostPosted: Sun Jul 15, 2018 7:13 pm
Got it. I get an XML file
PostPosted: Sun Jul 15, 2018 9:02 pm
Can you paste here?
Next
Return to Portal
