Custom Variables for my flow monitoring.
Related to the Portal
tkeracer619
Post by tkeracer619 »
I have been using some flow meters and IO modules to monitor flow on my tank for a few items. Right now I am using 4 sensors monitoring my GFO, Carbon, and BioPellets as well as one for the return to my anemone tank.
I was hoping you guys could help me figure out how to attach custom variables so I can view these rates in the portal.
My current code
    #define Actinic             1
    #define T5A                 2
    #define T5B                 3
    #define MH                  4
    #define Autofeeder          5
    #define Blank2              6
    #define FastFlush           7
    #define ReverseOsmosis      8
    byte IOIn[7];
    byte IOIn1[7];
    int Flow0;
    int Flow1;
    int Flow2;
    int Flow01;
    int Flow11;
    int Flow21;
    char text[12];
      ReefAngel.LCD.DrawDate(6, 122);
      ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
      ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
      strcat(text,"  ");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
      ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,4,"CBN:");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,15,"GFO:");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,26,"BIO:");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,4,"GPH");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,15,"GPH");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,26,"GPH");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,37,"DSP:");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,48,"BTA:");
      //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,59,"CAL:");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,37,"GPH");
      ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,48,"GPH");
      //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,59,"GPH");
      ConvertNumToString(text, Flow0, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 4, text);
      ConvertNumToString(text, Flow1, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 15, text);
      ConvertNumToString(text, Flow2, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 26, text);
      GetFlow1();
      ConvertNumToString(text, Flow01, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 37, text);
      ConvertNumToString(text, Flow11, 1);
      strcat(text,"");
      ReefAngel.LCD.DrawText(0, 255, 29, 48, text);
      //ConvertNumToString(text, Flow21, 1);
      //strcat(text,"");
      //ReefAngel.LCD.DrawText(0, 255, 29, 59, text);
      //ReefAngel.LCD.DrawGraph(5, 5);
      ReefAngel.FeedingModePorts = B00000000;
      ReefAngel.WaterChangePorts = B00000000;
      ReefAngel.OverheatShutoffPorts = B00000000;
      ReefAngel.LightsOnPorts = B00000111;
      ReefAngel.StandardLights(Actinic,11,0,24,0);  //Actinic schedule 11:00am - 12:00am
      ReefAngel.StandardLights(T5A,11,30,22,15);  //Blue Plus 1 schedule 11:30am - 11:15pm
      ReefAngel.StandardLights(T5B,11,45,22,30);  //Blue Plus 2 schedule 11:45am - 11:30pm
      ReefAngel.MHLights(MH,12,30,21,15,15);  //Metal Halide schedule 12:30pm - 9:15pm with 15min cool down
      ReefAngel.StandardLights(FastFlush,9,45,9,55);  //RO Fast Flush schedule 9:45am - 9:55pm
      ReefAngel.StandardLights(ReverseOsmosis,9,45,13,0);  //RO Fast Flush schedule 9:45am - 1:00pm
      GetFlow();
      GetFlow1();
      ReefAngel.Portal("tkeracer619");
    void GetFlow()
      Wire.requestFrom(9,7);
      if(Wire.available())
        for (int a=0;a<8;a++)
          IOIn[a]=Wire.read();
      Flow0=(IOIn[1]<<8)+IOIn[2];
      Flow1=(IOIn[3]<<8)+IOIn[4];
      Flow2=(IOIn[5]<<8)+IOIn[6];
    void GetFlow1()
      Wire.requestFrom(10,7);
          IOIn1[a]=Wire.read();
      Flow01=(IOIn1[1]<<8)+IOIn1[2];
      Flow11=(IOIn1[3]<<8)+IOIn1[4];
      Flow21=(IOIn1[5]<<8)+IOIn1[6];
Re: Custom Variables for my flow monitoring.
Try this:
    #define Actinic             1
    #define T5A                 2
    #define T5B                 3
    #define MH                  4
    #define Blank2              6
    #define FastFlush           7
    byte IOIn[7];
    byte IOIn1[7];
    int Flow0;
    int Flow1;
    int Flow2;
    int Flow01;
    int Flow11;
    int Flow21;
    char text[12];
      strcat(text,"  ");
      strcat(text,"");
      strcat(text,"");
      strcat(text,"");
      GetFlow1();
      strcat(text,"");
      strcat(text,"");
      //strcat(text,"");
      GetFlow();
      GetFlow1();
      ReefAngel.CustomVar[0]=Flow0;
      ReefAngel.CustomVar[1]=Flow1;
      ReefAngel.CustomVar[2]=Flow2;
      ReefAngel.CustomVar[3]=Flow01;
      ReefAngel.CustomVar[4]=Flow11;
      ReefAngel.CustomVar[5]=Flow21;
    void GetFlow()
    void GetFlow1()
Make sure to turn on custom variables features:
Open RAGen
Move to features tab
Check mark Custom Variables
Click Save
tkeracer619
Right on Roberto, ill give it a shot when I get home next weekend.
Thanks for the help!
tkeracer619
I can see the custom variables on portal. Is it possible to graph them, change the labels, and set up a text warning so that if the number falls below x then it sends the warning?
Here is my current code.
    #define Actinic             1
    #define T5A                 2
    #define T5B                 3
    #define MH                  4
    #define Blank2              6
    #define FastFlush           7
    byte IOIn[7];
    byte IOIn1[7];
    int Flow0;
    int Flow1;
    int Flow2;
    int Flow01;
    int Flow11;
    int Flow21;
    char text[12];
  //  #if defined DisplayLEDPWM && ! defined RemoveAllLights
  //    ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
  //    ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
  //  #else // defined DisplayLEDPWM && ! defined RemoveAllLights
  //    ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
  //  #endif // defined DisplayLEDPWM && ! defined RemoveAllLights
  //    pingSerial();
               ReefAngel.LCD.DrawText(0,255,75,3,"Display");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 80, 11, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,75,21,"Ambient");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 80, 29, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,90,39,"PH");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 80, 46, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,73,56,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 80, 64, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,4,21,"BIO:");
  strcat(text,"");
  ReefAngel.LCD.DrawText(COLOR_INDIANRED, 255, 29, 21, text);
  ReefAngel.LCD.DrawText(0,255,4,30,"BTA:");
  strcat(text,"");
  ReefAngel.LCD.DrawText(COLOR_INDIANRED, 255, 29, 30, text);
  ReefAngel.LCD.DrawText(0,255,4,3,"CBN:");
  strcat(text,"");
  ReefAngel.LCD.DrawText(COLOR_INDIANRED, 255, 29, 3, text);
  ReefAngel.LCD.DrawText(0,255,4,12,"GFO:");
  strcat(text,"");
  ReefAngel.LCD.DrawText(COLOR_INDIANRED, 255, 29, 12, text);
  //ReefAngel.LCD.DrawText(0,255,4,48,"DSP:");
  //ConvertNumToString(text, Flow01, 1);
  //strcat(text,"");
  //ReefAngel.LCD.DrawText(COLOR_INDIANRED, 255, 29, 48, text);
  //pingSerial();
  //ReefAngel.LCD.DrawText(0,255,4,59,"CAL:");
  //ConvertNumToString(text, Flow0, 1);
  //strcat(text,"");
  //ReefAngel.LCD.DrawText(COLOR_INDIANRED, 255, 29, 59, text);
  //pingSerial();
   ReefAngel.LCD.DrawOutletBox(12, 107, TempRelay);
   //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,47,3,"GPH");
   //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,47,12,"GPH");
   //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,47,21,"GPH");
   //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,47,30,"GPH");
   //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,47,48,"GPH");
   //ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,47,59,"GPH");
   GetFlow1();
      GetFlow();
      GetFlow1();
      //ReefAngel.CustomVar[0]=Flow0;
      //ReefAngel.CustomVar[3]=Flow01;
    void GetFlow()
    void GetFlow1()
I need to work on changing the labels for those.
Didn't have time... :(
To graph them, use:
http://forum.reefangel.com/status/chart ... &filter=c0
You can change c0 to whatever field you want.
To receive alerts, go to "Portal Settings" and enable "Send email notifications". You will then be able to enter an email and set triggers.
tkeracer619
Awesome thanks!
Is there a way to layer those graphs so more variables are shown at once or integrate it into the standard portal graph?
not right now :(
Only one at a time.
tkeracer619
Cool no worries. Thanks again for your help!
