Portal, data logging, app issues
Related to the Portal
reefoffillory
Re: Portal, data logging, app issues
Post by reefoffillory »
rimai wrote:Ahhh. I just realized you bought this unit used.
You will need to update the wifi attachment to point to the correct server:
http://forum.reefangel.com/viewtopic.php?f=3&t=4601
When doing this on Tera Term i'm getting 'Stary WiFly module configuration'
I have the Wifi Module plugged in to the computer, green light is flashing
reefoffillory
I changed it to COM3, and now it's slowly going through numbers after 'ftp:##:wait 'AOK'
reefoffillory
Got through it to where it gave me the option to 'Start WiFly module configuration' again, so I plugged the WiFi attachment back into the Reef Angel and the portal's still not working. My IP [internal and external] is still working though
Is there a way for me to log/store the data from my reef angel through my Internal.IP:2000/wifi or External.IP:2000/wifi?
And/Or auto-update and receive messages based upon parameters?
Can you post the log of tera term?
reefoffillory
rimai wrote:Can you post the log of tera term?
Is this what you're looking for?
x=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid Matties$2.4'
wait 'AOK'
sendln 'set wlan pass Password'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name www.reefangel.com'
wait 'AOK'
sendln 'set i h 104.36.18.155'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
reefoffillory
I changed the baudrate and it did something different this time. That might have been the issue
reefoffillory
CMD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid Matties$2.4
AOK
<4.41> set wlan pass Password
AOK
<4.41> set option deviceid ReefAngelWifi
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name http://www.reefangel.com
AOK
<4.41> set i h 104.36.18.155
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Fri, 03 Nov 2017 02:41:07 GMT
Connection: close
Content-Length: 326
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid Verb</h2>
<hr><p>HTTP Error 400. The request verb is invalid.</p>
</BODY></HTML>
Date: Fri, 03 Nov 2017 02:41:23 GMT
Connection: close
Content-Length: 326
</BODY></HTML>
I believe the Bad Requests came when I hit ctrl+C to to copy the text so that I could paste it here.
Good. Try to use it now.
It takes 5 minutes for the connection to go through. So, please allow 5 minutes before you check if the portal received any data.
reefoffillory
awesome - it's working now! Thanks Roberto!
reefoffillory
rimai wrote:Good. Try to use it now.
Got the portal working, and the app is working when I open it manually, but I keep getting error notifications on the app
Error 15: Timeout connecting to [IP address]
Error 13: Software caused connection abort
Error 13
Error 15
Error 13
Error 15
Error 13
Error 13: timeout
Error 13: No route to host
Error 13: Unexpected status line:GET / status/submitp.aspx?t1=771&t2=771&t3=771&ph761
I've also had problems with the skimmer/ATO not doing the delay after feeding/water change mode. I used the wizard to set up my code, and set the skimmer to have a 15min delay, the ATO to have a 20min delay.
I don't see anything in the code though to tell the controller to do the delays?
Also, I can't seem to be able to set my refugium light for anything less than 'opposite of display tank light outlet'
I'd like to be able to run my refugium for 8hours instead of 12 hours. Is this not possible using the wizard?
Can you post your code?
reefoffillory
rimai wrote:Can you post your code?
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
  ReefAngel.AddStandardMenu(); // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.StandardHeater( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.Relay.DelayedOn( Port5 );
    ReefAngel.Relay.DelayedOn( Port7 );
    ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port4 ) );
    ReefAngel.Portal ( "reefoffillory" );
I changed the part about the standard menu [as advance as my arduino/coding knowledge goes] and I changed the last part about the portal [that you said to do earlier]
I got this coding after using the Wizard
Well, you are using internal memory code and we can't see the settings you are using.
But, I just reread the post and there is no such thing as delayed start after feeding in the wizard.
For lights, if you use hard coded settings, you can pick the time to start and stop.
reefoffillory
rimai wrote:Well, you are using internal memory code and we can't see the settings you are using.
I must have misunderstood the wording from the wizard, I thought it said under 'delayed start' that it's the amount of time that outlets are shut off after entering feeding and/or waterchange mode.
Is it better to use internal memory code or another type? I'm guessing this is in relation to the second screen of the wizard? I don't really need to be able to adjust the settings in the portal - I don't mind hooking my laptop up to the RA in order to change settings
Yes, you better off using hard coded settings.
delayed start is the amount of time the outlet remains OFF after one of the following: exiting water change mode, feeding mode and controller start up
so if you set port1 to have a 1 minute delayed start, it won’t turn on until 1 minute after you have 1 of the 3 previously mentioned scenarios.
this is useful if you have a powerhead that is out of the water during water changes and it takes your return pump a minute to get the water level back up to normal. so you wouldn’t want that powerhead on and running out of the water immediately after your water change.
reefoffillory
binder wrote:delayed start is the amount of time the outlet remains OFF after one of the following: exiting water change mode, feeding mode and controller start up
That was how I intended to use it, I wanted my skimmer to stay off for 15 minutes, and my ATO to stay off for 20 minutes (how I set it up in the wizard) but it's not working, going to try again sometime this week
Unless someone changed the libraries, the delayedstart is only applicable to power on delays.
reefoffillory
rimai wrote:Unless someone changed the libraries, the delayedstart is only applicable to power on delays.
I tried searching the forum for information, but couldn't find anything. Am I able to download the data in the portal history to a form which is able to be manipulated such as a comma delimited/excel etc. file?
I'd like to be able to log my data for more than 3 days at a time, even if that means I have to download data every 3 days and compile it into a spreadsheet myself.
Is there already the capability to do this? I only see the option on the webchart to export image files
Sure. You can get a json formatted file.
http://forum.reefangel.com/status/jsonp ... &filter=t1
reefoffillory
rimai wrote:Sure. You can get a json formatted file.
Thank you for the response. I will be the first to admit that I am not as technically savvy as I would like to think. Does this pull the current status? How far back does it go?
I noticed that when I click on that link I only see temperature info, and no pH info. I also don't see an indication of time/sequence [unless i'm missing something].
I have never heard of JSON before, but I don't want to do anything too crazy with the data, just be able to see a chart of my temp/pH changes and be able to graph it in Excel or Google Sheets or something similar.
I also realize you're not in the business of free tech lessons so I understand if you don't have any further help to offer!
Thanks again!
the example given just pulls the current status for t1, hence the filter=t1 section.
json is just a way to format key value pairs.
there should be a way to get a complete data chunk in xml formatted response from the portal and that would (at least i think but don’t remember off hand since i haven’t looked for a while) include a date & time stamp. that’s what i do in my android app when the user asks for the data from the portal. i don’t have the exact url handy but can get it if you want.
xml and json are the only 2 ways to get the formatted data.
It only goes the same as the portal.
This is the url the portal uses to pull data.
If you don't know how to manipulate json on excel, you can use this:
https://json-csv.com/
To manipulate data on excel, just google.
This one is the first one it came up with:
https://www.youtube.com/watch?v=CjnsX81qWUg
reefoffillory
binder wrote:the example given just pulls the current status for t1, hence the filter=t1 section.
That would be great, I'd like time & Value for the data so that I can graph it.
I am able to split the values in the JSON file, but it's just not valuable without a date/time reference.
The value before the ,[reading] doesn't seem to mean anything for my purposes?
Thank you guys!
Really hoping to get these last few parts of the controller figured out before I decide to buy some more modules and expand it =)
I do have the android app linked to my portal - is it easier to get the data [including date/time/value] through the app? I am okay with having to manipulate/separate the data out in excel once I get a file with the data in it.
The first column would be date and time in unix (EPOCH) format.
Thank you guys!
there currently is no way to export the data from my android app.
so your best solution is to do what Roberto suggested or do what I mentioned. I personally don't know the json format and have not looked at it to understand it better. I just parse the xml data. regardless, to do what you want you will need a script to do the following:
1. query the portal for the data (xml or json)
2. save/process the data (if necessary)
3. import into excel
you just need to figure out what route you want to take and get started and then ask questions if you encounter any along the way.
