In Live more, the Portal doesn't pull data from the server. It pulls data from the controller, but it doesn't store it.
To store it, you need to have the Portal() function in your code and you need to make sure you have the wifi attachment setup properly.
Which app did you use to configure it? Dave's or the java app that comes with the Reef Angel Installer?
Issue: All inputs showing as "OFF" state on portal
symon_say
- Contact:
Re: Issue: All inputs showing as "OFF" state on portal
Dave's because java app was giving me some trouble, because i use static ip for the controller.
i have this in my code string:
ReefAngel.Portal( "Symon_say" );
ReefAngel.ShowInterface();-
Make sure that when you setup with Dave's utility, you also click "Save Remote Settings" with reefangel.com selected.
symon_say
- Contact:
Just to inform i set everything with the java app and still have the same problem, set it with Dave's app and with reefangel.com selected and is working again.
Thanks to all.
Thanks to all.
