Android App/Portal Connection
I am having problems finding the portal connection. I have downloaded the latest RAgen and libraries. Is there a step by step instruction page to be able to utilize the Android App? I don't know if I am even asking the right question.
Re: Android App/Portal Connection
So you have your wifi attachment setup yet?
If so, do you know the ip address?
Yes, I have the wifi attachment and it is working with my wireless router and i have the internal IP for it, 192.168.1.150. I set it up as a static IP so it wont change.
Ok, so you can open the android app and hit your menu button on your phone.
I will open a menu with the button settings. Click on it.
Click Device and choose controller
Click Host Information and then click on hostname. Enter your ip address: 192.168.1.150
Click on Port and make sure that it is 2000
Click on user id and enter your forum username.
That's it.
You should be able to get the app to communicate with your controller now, assuming that you enabled wifi feature when you uploaded your code.
That's it.
Thank you for this information. Everything works.
