Portal not showing ATO relay activity
Related to the Portal
YuppiWanna
Post by YuppiWanna »
My relay activity graph is showing all relay activity but the ATO. The ATO is set to "auto" on the dash board.
Re: Portal not showing ATO relay activity
It's not designed to show the ATO activity. It happens too fast.
The Portal only receives data every 5 minutes.
If the ATO event starts and ends anywhere in between 5 minutes, you will not see the activity.
