Last step to my wifi. Troubles getting portal to work
Re: Last step to my wifi. Troubles getting portal to work
I agree, if ddns can be taken out of the equation it would make it easier for entry level users, and the Portal, iPad/iPhone and Android apps can pick-up the last ip address sent to the portal would be the best solution.
Ok, I've made the change.
I've done some tests and it seems to be working.
If anyone finds any irregularity, please let me know.
Everything is now working perfectly. Thanks so much for everyones help!!!
Deleted IP address in Portal settings, opened Portal and it could not find my external address. Opened portal settings and the IP address field had been repopulated.Ok, I've made the change.
So all it is working ok, good fix
I did get an Error splash screen after I turned a relay from auto to off as a test. But the relay did what Ihad asked. Reset to auto and tried it again and could not replicate error. Just one of those things I guess!
