Portal
Related to the Portal
rschneider77
Portal
Post by rschneider77 »
I have been trying to get my email alerts to send me an email, but just can't get it to work. I have added the line of code you have stated in the other posts, but still no luck. Any suggestions?
Re: Portal
Looking at the log from your controller, it hasn't sent anything for the past couple hours.
Also, it seems you have the Client also sending data, which is probably interfering with data too.
Can you make sure that the Client is not sending data and you only have the controller itself sending data to the portal?
rschneider77
Re: Portal
The Client is now, not sending data to the Portal.
Re: Portal
There is still no activity from your controller.
Do you have this in your code?
ReefAngel.Portal("rschneider77");
rschneider77
Re: Portal
I do, but I also have the "keycode", it's in this form.
ReefAngel.Portal("rschneider77","xxxx");
Should I change it to just this? If so, why?
Re: Portal
Ok, if you have the security key in your code, you also need to set the security key on the Portal.
Please open the Portal and click on Portal Settings.
Enable the security key and enter the same key as shown in your code.
Click Save.
rschneider77
Re: Portal
Yeah. The security key has been enabled in the Portal AND it has been in the code for the the entirety of this thread. I also noticed that in the Portal, all my relays display off. Could this all be something else maybe? Maybe my wireless?
Re: Portal
That was probably the Client messing with the data on the Portal.
Try disabling the key and remove from your code.
rschneider77
Re: Portal
Disabled the key, removed the key from code. Portal still does not show relay status. And no email alerts. Any ideas? Can the wifi module have code in it concerning the portal?
// Autogenerated file by RAGen (v1.2.2.171), (06/04/2012 17:53)
// RA_060412_1753.ino
#define wifi
#define SIMPLE_MENU
#define ENABLE_ATO_LOGGING
    ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port8);
    ReefAngel.SingleATOLow(Port1);
    ReefAngel.StandardLights(Port2, 21, 30, 9, 30);  //Refugium schedule 9:30pm - 9:30am
    ReefAngel.StandardLights(Port3, 9, 30, 21, 30);  //LED Actinic Front schedule 9:30am - 9:30pm
    ReefAngel.StandardLights(Port4, 10, 30, 20, 30);  //LED Daylight schedule 10:30am - 8:30pm
    // This sends all the data to the portal
    // Do not add any custom code that changes any relay status after this line
    // The only code after this line should be the ShowInterface function
Re: Portal
I don't see any log of your controller sending data recently.
How long ago have you configured your wifi attachment?
rschneider77
Re: Portal
WiFi was reconfigured about two weeks ago.
Re: Portal
Are you able to connect to the controller through wifi?
Did you use the same wifi utility in this thread?
http://forum.reefangel.com/viewtopic.php?f=15&t=345
rschneider77
Re: Portal
i can connect through wifi and such. no i didnt use that app. i can only find the other one from github
Re: Portal
Ok. With Dave's utility, you have to make sure you also set the remote settings to reefangel.com
Can you do that and try again?
rschneider77
Re: Portal
The software I am using doesn't look like that. I downloaded "davemolton-Graphical-Wifi-Utility-a45bcdf" from github. Is that the correct software?
Re: Portal
It's ok to use Dave's utility too. Just make sure to set the remote settings to reefangel.com if you use Dave's utility.
rschneider77
Re: Portal
What is the utility shown in that thread?
Re: Portal
It's the one that comes with the new Reef Angel Installer.
