Portal
Related to the Portal
rschneider77
Re: Portal
Post by rschneider77 »
WiFi was reconfigured about two weeks ago.
Re: Portal
Are you able to connect to the controller through wifi?
Did you use the same wifi utility in this thread?
http://forum.reefangel.com/viewtopic.php?f=15&t=345
rschneider77
Re: Portal
i can connect through wifi and such. no i didnt use that app. i can only find the other one from github
Re: Portal
Ok. With Dave's utility, you have to make sure you also set the remote settings to reefangel.com
Can you do that and try again?
rschneider77
Re: Portal
The software I am using doesn't look like that. I downloaded "davemolton-Graphical-Wifi-Utility-a45bcdf" from github. Is that the correct software?
Re: Portal
It's ok to use Dave's utility too. Just make sure to set the remote settings to reefangel.com if you use Dave's utility.
rschneider77
Re: Portal
What is the utility shown in that thread?
Re: Portal
It's the one that comes with the new Reef Angel Installer.
