Portal with ClientSuite 2.2
Related to the Portal
My link to send info on the Client Suite is failing? Help? Ideas? It was working just a day ago.
Re: Portal with ClientSuite 2.2
I should mention my webanner still works but my relays don't show like they did before?
Your controller doesn't seem to be sending data.
I recall seeing your code having key on the Portal() function.
You also have to enter the same key on the Portal, on the Portal settings section.
Entered the key...still no relay display...?
When I click the link on client suite...this is what I get:
Page Not Found
The Page "image_style7" was not found.
There are no Pages with similar name or title.
You can also perform a search or create the Page (could require login).
Still have questions? Please send me an email to info@reefangel.com
Here's what I've got going...the moonphase on lowATO is working great now.
/ Autogenerated file by RAGen (v1.2.2.171), (05/29/2012 16:15)
// RA_052912_1615.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.SingleATO( true,Port2,60,0 );
    pinMode(lowATOPin,OUTPUT);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.Relay.On(Port5);
    //randomSeed(analogRead(0));
    //ReefAngel.Init();  //Initialize controller
    //ReefAngel.Timer[1].SetInterval(random(15,35));
    //ReefAngel.Timer[1].Start();
    //ReefAngel.Relay.On(Port5);
    ReefAngel.StandardLights( Port1,19,0,6,30 );
    ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights( Port7,6,0,20,0 );
    ReefAngel.StandardLights( Port8,7,0,19,0 );
    //////// ReefAngel.Wavemaker1(Port5);
    /////// ReefAngel.Wavemaker2(Port6);
    //ReefAngel.PWM.SetActinic( MoonPhase ) Test for Meanwells
    ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
    ///if ( ReefAngel.Timer[1].IsTriggered() )
          ///  ReefAngel.Timer[1].SetInterval(random(15,35));
          ///  ReefAngel.Timer[1].Start();
           /// ReefAngel.Relay.Toggle(Port5);
          ///  ReefAngel.Relay.Toggle(Port6);
    if (hour()>=6 && hour()<20)
    analogWrite(lowATOPin,0);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
    ReefAngel.Portal("DrewPalmer04", "********");
Client links are outdated.
Quick question, do you have the wifi attachment?
Is this a new thing? The client links being outdated? It was working a few days ago just fine? No I do not have the wifi attachement. That's why I was using the clientsuite.
Tuesday, June 05, 2012 5:45:59 PM to be exact...this is the last time I have had communication with the portal.
Oh, now it is expained...
Sorry, if you don't have wifi you do need to use the client.
And if you use the client, you need to remove the key on the portal settings.
I'm sorry. I just assumed you had the wifi attachment when I saw Portal() in your code.
I removed the Portal ()
Still when I use client suite...I click the webbanner link and I'm getting "page not found"....this worked before...not sure what's going on.
The link in the Client is outdated. It has always been ever since we moved servers and implemented the Portal.
The new links can be acquired on the portal, in the webbanner section.
That's weird. I was using the client suite link up until Monday. That's the portal link I have showing. No relay support to display this way?
Technically the old banners should work, but I haven't looked at them for so long.
In that case. I guess I have a connection issue to the portal. I'll have to try and figure out why
Think i've found the problem in the error log:
*****6/8/2012 7:04:40 AM*****
Message:
The remote server returned an error: (500) Internal Server Error.
StackTrace:
   at System.Net.HttpWebRequest.GetResponse()
   at ReefAngelClient.Classes.Controller.SendParamsToWebsite()
*****6/8/2012 7:07:42 AM*****
Message:
StackTrace:
*****6/8/2012 7:10:40 AM*****
Message:
StackTrace:
*****6/8/2012 7:13:42 AM*****
Message:
StackTrace:
*****6/8/2012 7:16:43 AM*****
Message:
StackTrace:
*****6/8/2012 7:19:40 AM*****
Message:
StackTrace:
*****6/8/2012 7:22:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:25:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:28:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:31:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:34:55 AM*****
Message:
StackTrace:
*****6/8/2012 7:38:02 AM*****
Message:
StackTrace:
*****6/8/2012 7:40:55 AM*****
Message:
StackTrace:
*****6/8/2012 7:43:59 AM*****
Message:
StackTrace:
*****6/8/2012 7:47:28 AM*****
Message:
StackTrace:
*****6/8/2012 7:50:07 AM*****
Message:
StackTrace:
*****6/8/2012 7:53:02 AM*****
Message:
StackTrace:
*****6/8/2012 7:55:56 AM*****
Message:
StackTrace:
*****6/8/2012 8:11:11 AM*****
Message:
StackTrace:
*****6/8/2012 8:14:25 AM*****
Message:
StackTrace:
*****6/8/2012 8:17:37 AM*****
Message:
StackTrace:
*****6/8/2012 8:22:54 AM*****
Message:
StackTrace:
*****6/8/2012 8:25:52 AM*****
Message:
StackTrace:
I think I was able to fix whatever was wrong with the server.
Yep you've got it...THANKS!
I think the clientsuite server might be messing up again! Thanks :)
Thanks for reporting
