Portal with ClientSuite 2.2
Related to the Portal
Re: Portal with ClientSuite 2.2
I removed the Portal ()
Still when I use client suite...I click the webbanner link and I'm getting "page not found"....this worked before...not sure what's going on.
The link in the Client is outdated. It has always been ever since we moved servers and implemented the Portal.
The new links can be acquired on the portal, in the webbanner section.
That's weird. I was using the client suite link up until Monday. That's the portal link I have showing. No relay support to display this way?
Technically the old banners should work, but I haven't looked at them for so long.
In that case. I guess I have a connection issue to the portal. I'll have to try and figure out why
Think i've found the problem in the error log:
*****6/8/2012 7:04:40 AM*****
Message:
The remote server returned an error: (500) Internal Server Error.
StackTrace:
   at System.Net.HttpWebRequest.GetResponse()
   at ReefAngelClient.Classes.Controller.SendParamsToWebsite()
*****6/8/2012 7:07:42 AM*****
Message:
StackTrace:
*****6/8/2012 7:10:40 AM*****
Message:
StackTrace:
*****6/8/2012 7:13:42 AM*****
Message:
StackTrace:
*****6/8/2012 7:16:43 AM*****
Message:
StackTrace:
*****6/8/2012 7:19:40 AM*****
Message:
StackTrace:
*****6/8/2012 7:22:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:25:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:28:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:31:56 AM*****
Message:
StackTrace:
*****6/8/2012 7:34:55 AM*****
Message:
StackTrace:
*****6/8/2012 7:38:02 AM*****
Message:
StackTrace:
*****6/8/2012 7:40:55 AM*****
Message:
StackTrace:
*****6/8/2012 7:43:59 AM*****
Message:
StackTrace:
*****6/8/2012 7:47:28 AM*****
Message:
StackTrace:
*****6/8/2012 7:50:07 AM*****
Message:
StackTrace:
*****6/8/2012 7:53:02 AM*****
Message:
StackTrace:
*****6/8/2012 7:55:56 AM*****
Message:
StackTrace:
*****6/8/2012 8:11:11 AM*****
Message:
StackTrace:
*****6/8/2012 8:14:25 AM*****
Message:
StackTrace:
*****6/8/2012 8:17:37 AM*****
Message:
StackTrace:
*****6/8/2012 8:22:54 AM*****
Message:
StackTrace:
*****6/8/2012 8:25:52 AM*****
Message:
StackTrace:
I think I was able to fix whatever was wrong with the server.
Yep you've got it...THANKS!
I think the clientsuite server might be messing up again! Thanks :)
Thanks for reporting
