portal dynamic Ip question
Related to the Portal
ahmedess
Post by ahmedess »
I can connect to the portal if i put my current ip or dyndns just fine but when i either update the Reef Angel Wifi Address to a blank field or reset my router to test whether the portal will work again if my ip changes it doesnt work and says unreachable
I dont understand how is it supposed to work if i m using a dynamic ip address and how would it still connect to my controller if my ip changes
Re: portal dynamic Ip question
It takes about 5 minutes for the Portal to receive the latest ip address after you blank it out.
The controller sends data to the portal every 5 minutes. So, the next time the controller communicates with the Portal, it will send your latest ip address and the portal will update the field all by itself.
ahmedess
Post by ahmedess »
How do i know if my webbanner is working and my controller is sending info to your server
Just look at the last modified timestamp
ahmedess
Post by ahmedess »
Reef Angel wifi address: (update)
My reefangelid:
ahmedess
Connection Status:
Unreachable Address
Last Update:
June 29, 2012 1:27:48 PM GMT+02:00
Displaying data from:
Webbanner database
Does that mean the controller is not sending info periodically to your server cause i think that time stamp is when i was connecting using my ip address typed in
I don't think your wifi attachment is sending anything to the server:
http://forum.reefangel.com/status/banne ... d=ahmedess
ahmedess
Post by ahmedess »
Why is that?
Probably because you missed one step on your wifi attachment setup.
You probably used Dave's wifi utility and forgot to click save remote settings button.
Can you try doing that?
ahmedess
Post by ahmedess »
Yup i used daves utility. I ll check it when i get back home
ahmedess
Post by ahmedess »
what should the remote host ip be on my computer on dave's reef angel wifi utility?
reefangel.com
Poiromaniax
Post by Poiromaniax »
You can follow my guide to remote wifi setup. My portal works perfectly as long as dyndns has been updated. If you are using dyndns, do you have the updater constantly running?
