Custom Variables
Custom Variables
Were the custom variables removed from the portal? They are no longer showing on my dashboard.
Re: Custom Variables
No, they were not removed. Make sure that you have at least one variable that is not zero.
The logic of the Portal will hide anything that has all zeros.
It assumes that you are not using that feature.
What I did on mine was to put C8=255, so the Portal shows something all the time.
Got it, that makes sense. For some reason, prior to libraries 1.0, my ATO timeout was 254 if not timed out, and 255 if timed out. I had a custom variable keyed to that value. That issue had disappeared since upgrading to 1.0.
