Ahhh. you can't use timer 4.
It's used by the portal function.
Change your code to use timer 1 or 2
Portal isn't updating for me today...
Yeah, that was the same vortech code i copied and made the same mistake. I did post the bug at the end of that thread...Roberto can you edit other posts so people don't make the same mistake again? Or maybe move the feed timer to something not so easily reused...
Re: Portal isn't updating for me today...
OK, I changed it to Timer 1. Let's see if that updates my webbanner.
Doesn't look like it yet. Maybe it just needs some time to sync?
**EDIT** Yep, it updated my webbanner after a few minutes. Thanks Roberto!
