Ato trigger for portal
How do I set the trigger for on the portal to email me when the high float switch is made on the controller. I'm guessing there is some code in the custom variables to add to the controller. But not sure what to add or where.
Re: Ato trigger for portal
Last Stupid Question but Where does it go?
#define Fan 8
#define LightWhite 7
#define Main Pump 6
#define Skimmer 5
#define Heater 4
#define Powerhead 3
#define ATO 2
#define LightBlue 1
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define CUSTOM_VARIABLES
byte x = 6;
byte y = 2;
byte t;
char text[8];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,3,17,"Daryl's 90 Reef");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Water");
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.FeedingModePorts = Port4Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 828 );
ReefAngel.StandardLights( Port1,14,15,21,15 );
ReefAngel.SingleATO( true,Port2,420,0 );
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off (Port2);
ReefAngel.StandardLights( Port7,14,45,20,45 );
ReefAngel.StandardFan( Port8,815,816 );
ReefAngel.Relay.DelayedOn( Port5,5 );
#define Fan 8
#define Main Pump 6
#define Skimmer 5
#define Heater 4
#define Powerhead 3
#define ATO 2
#define LightBlue 1
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
byte x = 6;
byte y = 2;
byte t;
char text[8];
On the portal.
Go to "Portal Settings" and enable send email notifications.
Then you can add any trigger you wish.
Got it.. Should the Ato high light on the portal be green but go red when the switch makes?
d
d
Not sure why I keep getting an email alert even when the switch isn't made.. I checked to make sure the switch is working and when the ato is calling for water I can trip the upper level switch as a failsafe and it turns off the ato port.
Anything else to check?
Lol I was gonna change it to that just for giggles but I was SCARED.. hehe
thanks Now to figure out my heater programming..
Daryl
Daryl
