Portal control of Dosing Pumps
Related to the Portal
Sebyte
Post by Sebyte »
I am trying to set up an RA Dosing pump so that I can fine tune the setting via the portal.
I can toggle the ports from the Dash Board, but am unable to change their operation through the memory setting page.
This is the code I have in my .ino file
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
Also the ports are always in an ON state when the RA is rebooted.
Any advice will be welcome.
Re: Portal control of Dosing Pumps
On as in overriden on?
Sebyte
Post by Sebyte »
In the portal they show as "Auto" and I can turn them manually on and off via page.
When set to "Auto" the power packs plugged into ports 7 & 8 are live with the led on. The settings in memory are having no effect on changing the state of the relays.
Can you post your entire code?
Sebyte
Post by Sebyte »
Here is my .ino listing.
// ATO build Plus Dosing **********************************
// 14/10/2012
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
    ReefAngel.Relay.On( Port1 ); // Skimmer
    ReefAngel.Relay.On( Port6 ); // Pumps
    // ReefAngel.SingleATOLow( Port2 );
  ReefAngel.SingleATO(true,Port2,600,0);
    // true = Low ATO port
    // Port1 = port you are using for ATO pump
    // 600 = timeout in seconds
    // 1 = run only once per hour. To have it run many times per hour, just put 0.
    ReefAngel.StandardFan( Port4 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.Wavemaker1(Port5);
  // Activate Watch Dog Timer at 6am and 6pm
  if ((now()%86400)==21600) delay(1000);
  if ((now()%86400)==43200) delay(1000);
  // Wavemaker not available 9 pm to 10 am
  if ( (hour() >= 20) || (hour() <= 9) )
    ReefAngel.Relay.Off(Port5);
  //LED SETUP
  ReefAngel.StandardLights(Port7,10,0,22,0); // Actinic LED Lights on at 10:00am and off at 10:00pm
  ReefAngel.StandardLights(Port8,12,0,21,0); // Daylight LED Lights on at 12:00pm and off at 9:00pm
  // PWMParabola(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte oldValue)
  // startHour - Hour of the start the slope
  // startMinute - Minute of the start the slope
  // endHour - Hour of the end of the slope
  // endMinute - Minute of the end slope
  // startPWM - Beginning PWM value
  // endPWM - Ending PWM value
  // oldValue - Should be the startPWM value or the existing/current PWM value (ReefAngel.PWM.GetActinicValue() or GetDaylightValue())
  ReefAngel.PWM.SetActinic(PWMParabola(10,0,22,0,0,70,0));
  // Actinic PWM % starts raising from 0% to 70% and back down to 0% from 10:00am to 10:00pm forming a parabola.
  ReefAngel.PWM.SetDaylight(PWMParabola(12,0,21,0,0,60,0));
  // Daylight PWM % starts raising from 0% to 60% and back down to 0% from 12:00pm to 9:00pm forming a parabola.
// NOTE light max values reduced due to algae increase. Blue from 100% to 80%, white from 80% to 70% - 26th September 2012
  /* NOTES----------------------------------->>>>
   If you get a compile error similar to this:
   'class ReefAngelClass' has no member named 'PWM'
   Please make sure that you enabled Display LED PWM on your features file.
   Open RAGen and make sure you have Display LED PWM checked under the Features tab.
   Or, you can manually edit the file.
   The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
   #define DisplayLEDPWM
    ReefAngel.Portal( "sebyte" );
// CODE ENDS //
Sebyte
Post by Sebyte »
Sorry I think I can see where the problem is in the LED script I forgot to move the ports.
Yeap. that's what it is :)
