Roberto
I was wondering if it would be possible to add an ATO timeout reset to the Portal.
With the peristaltic pump I sometimes find that I get a timeout as the flow rate is low and I am pumping from the basement to the first floor.
Although I want the safeguard of the time out feature, when I am traveling it would be a great help to (a) know if a timeout has occurred and (b) be able to reset it.
Just a thought
ATO timeout reset
Re: ATO timeout reset
I need to change the tabs to be in a single one with all commands in it
Thanks for the suggestion.
