Hello
I set up my controller back in August and the app and portal worked. I had some tank issues (cracked bottom glass plate) and took the tank down. I am setting the tank back up now and the app works fine but the portal does not.
I checked my ip address and that is the same as it was back in August
I did the port forwarding again and that does not help.
Let me know if any has any suggestions.
iphone app works but portal does not
Re: iphone app works but portal does not
Please double check the port forwarding.
If you check the port 2000, it must show as open: http://www.yougetsignal.com/tools/open-ports/
