Android app updating
Related to the Portal
riggeek
Post by riggeek »
Not sure what the problem is here
I can log in too the portal and the tank data is correct.
If I use locale on the Android app it shows correct.
If I tell the Android app to log into the portal the data shows wrong. It is able to log in with out any errors.
Not sure where too start chasing this one out to fix it, ant ideas?
riggeek
riggeek
Re: Android app updating
Post by riggeek »
Just noticed the signature banner is wrong to
riggeek
The controller is not sending data to the server for some reason.
riggeek
Post by riggeek »
when I log into the portal I show correct data
the date it is only wrong using the Android app log into portal, or the signature web banner.
where would I start to troubleshoot this.
thanks for any help, as I am not sure where to start on this
riggeek
Did you reconfigure your wifi at all?
riggeek
Post by riggeek »
We did a few weeks ago, but it has been writing since then
riggeek
riggeek
Post by riggeek »
should I try to reconfigure the wifi again?
What has me confused is the portal dash board works, but the other things don't.
I also noticed that the web chart and relay activity stopped working on the Sunday November 4 at about 7 AM.
riggeek
Yeah, try that first and let's see how it goes.
riggeek
Post by riggeek »
The wifi set up went thou with out any problems
Got my IP of XXX.XXX.1.3 2000
Then i went to this part
Setting up your Reef Angel Wifi attachment using your Reef Angel Controller
1. Start your Arduino software
2. Open the wifi setup code by going to menu File->Sketchbook->Example Codes and selecting
WifiSetup
3. Modify the settings to match your own wifi authentication
4. Upload the code to your Reef Angel Controller
5. After uploading the code, disconnect the USB-TTL converter cable and connect your wifi attachment.
For more information on how to connect the wifi attachment, please refer to “Connecting your
Reef Angel Wifi attachment to the Head Unit” in this manual
6. Press the joystick button.
7. If the wifi attachment is able to connect successfully to your wifi network, it will present you with the
IP address that was assigned to it. This is the number you will need to use on any of the
available apps.
8. You are now ready to start using your wifi attachment.
and get this message
status 8130
all ready set up
but it does appear to be working now
Thanks for the assistance
I will keep a eye on it for a few days
riggeek
