EMAIL NOTIFICATION
Related to the Portal
mineman@mac.com
EMAIL NOTIFICATION
Post by mineman@mac.com »
Every hour I recieve emails saying that my ph is 0, but when I check on the portal or iPhone app, ph is fine.
Re: EMAIL NOTIFICATION
I'm looking at the setting of your email triggers and you have a trigger for PHE which is for the pH expansion module.
PHE<6.8
Because you don't have the expansion module the value of PHE is 0.
Changing PHE to PH should fix the problem.
mineman@mac.com
EMAIL NOTIFICATION
Oh, stupid me. Thanks!
barbianj
Post by barbianj »
I had the same thing happen to me, but I just realized why it happened. When you edit the pH notification in the Portal, it changes from PH and defaults to PHE. You have to go back up the list and select PH. I didn't catch it the first time.
EMAIL NOTIFICATION
barbianj wrote:I had the same thing happen to me, but I just realized why it happened. When you edit the pH notification in the Portal, it changes from PH and defaults to PHE. You have to go back up the list and select PH. I didn't catch it the first time.
+1 it's happened to me a few times...
Oh.. Thanks for informing :)
I'll check what the problem is.
