Wifi Attachment and portal problem..
Hi Roberto!
I have a problem with Wifi Attachment and the portal.
1. I set up the Wifi Attachment and for a few weeks everething worked OK. Today even though the green light shows that the module is connected with my router, i cannot have access to the RA through my iphone or my tablet supporting Android ( not for my router nor when i am out my home), the Wifi Attachment does not send any information to the portal. I have disconnected and reconnected the Wifi Attachment from the RA head unit and yet nothing change. This is the second time that happens since my purchase. Is there anything i can do?
2. Since the start that I installed Wifi Attachment the Portal is updated but it gives me a message '' Unreachable address'' and won't allaw me to open, close or give any kind of order to the relay box. How can i f;ix this?
Thank you in advance.
Re: Wifi Attachment and portal problem..
Also i can not ping the wifi attachment adrress.
OK!!! i update the wifi atachment and setup from beginig and all the problems it's fixed!!!
Again the same today...... The portal show me ''Unreachable address'' and do not let me give any kind of order to the relay box.
I try to setup my router with DDNS properly to connect my Reef Angel Controller remotely (from portal). The DDNS board in my router is the next:
DDNS
Enable
Service Type (?)
Server (?)
Username (?)
Password (?)
WAN Connection (?)
Hostname (?)
Can someone tell me how to fill the above board??
DDNS
Enable
Service Type (?)
Server (?)
Username (?)
Password (?)
WAN Connection (?)
Hostname (?)
What Brand of router are you using? What DDNS provider are you using?
The router is ZTE: ZXV10 H108L
The DDNS provider is WIND (name of internet provider)
I looked for information on your internet provider and didn't see anything for the DDNS service...
Here is a list of several DDNS providers some are free at the top of the list.. I've used Afraid.org and no-ip before
http://dnslookup.me/dynamic-dns/
Most of the sites let you come up with your own link name which then gets forwarded to whatever your ip address changes to.
You will also need to setup port forwarding in your router to forward the port 2000 to the Reef Angel wifi adapter ip address.
Is nesesary the DDNS for remotely conenect?? The www.dyndns.com dont let me create host name if i don't pay.
In Afraid.org i dont know how create host name........... I bored to try.
At last!!!!The problem it was the portal (2000)in my router. I open it (port forwarding) and now works perfect!!!
Wahooooo!!!
I know it was so sible and i am so newwwwww!!hahahaha!!
