port forwarding issues
I think we may need to confirm your wifi module settings via serial...I'll wait for Roberto with the commands...but your wifi module isnt on the network based on what I am seeing...
Just curious though, can you disconnect the wifi module and retry the ping? I still feel like there is an ip,conflict...maybe wait a few minutes after disconnect...
Also can you try pinging other devices in your "my network" screen from the router and your laptop and see what the results look like?
Re: port forwarding issues
Ok so i reset the router and now my rawifi is set to 192.168.1.4 but after running the wifi utility now i get a blinking blue light and the unit wont connect to the router. i went a forwarded the ports to the new ip to no success
i cant get the wifi unit to stay connect to the network for more then 45 seconds the the blue light starts going crazy
heres ss of my settings
- Capture13.PNG (47.15 KiB) Viewed 6452 times
- Capture14.PNG (33.51 KiB) Viewed 6452 times
- Capture15.PNG (48.7 KiB) Viewed 6452 times
Can you ping the laptops ok from the desktop / router and vice-versa? At this point just sounds like something didn't configure properly with the module. I would look to reset it to factory and start again.
- DrewPalmer04
Agree with this. If you can ping everything else now except the module we need to start from factory with itlnevo wrote:Can you ping the laptops ok from the desktop / router and vice-versa? At this point just sounds like something didn't configure properly with the module. I would look to reset it to factory and start again.
I agree. I think you need to reset the wifi module to factory settings. Also find out what version of software your running on the wifi module as well.
ok i can only ping devices for my desktop. when tring to ping my destop from my laptop it tells me request timed out. i cant ping the wifi module form any device i get unreachable host
Ok...you may have a firewall running on your desktop preventing other machines from pinging it. I still think we should reset the wifi module and reconfig. Also dump the settings through hyper terminal with "get e" I believe... If you can't ping the wifi module from desktop or router then it's not staying on the network. You may need to try that beta firmware too, but I don't think we are at that point yet...
first off i wanna thank everybody who helped me get this thing right. and a big shout out to rimai for his remote access skillz. we ( or should i say he ) figured out that it was my router, so i installed a second router and he got it all configured from there. everything is running great for the past hour so well see how everything goes.
thanks again everybody, my new picaso clownfish pair are greatful as well
- IMAG0797.jpg (101.91 KiB) Viewed 6394 times
Wahoo... Great looking Fish!!
thanks i cant wait to get tem in the tank now that the wifi is set up the tank is complete,cycled and ready to be stocked. now got to get through a little QT period and in the tank they go.
thanks again dbmet for all your help through this process. now i get to play with it now that its running the way i wanted..
ok so the wifi has been running great. no issues so far.
now i would like to know a little bit more info on the dynamic dns. i have a no-ip.com account. can one of u guy chime in and help a (getting smarter everyday) noob out?.....
Under the advanced setting on the verizon router, you can setup Dynamic DNS. You can add the no-ip.com acount info and the router will update the address.
I'm not sure how no-ip.com works, but wiht dyn-dyns your account name is your dns name...
So for me, I have easte.dyndns.org and I put my account info into the router. The router updates dyndns anytime the external IP changes. And in my iPhone I pount to easte.dyndns.org port 2000 for my ReefAngel and it connects back to my router.
It should be fairly straight forward. The only problem is for dyndns I have a grandfathered free account so I have the client also running on my computer to make sure it logs more frequently otherwise I lose my account if not updated every 30 days...
No-ip works the same way except for deleting of the account..Lol
You need your server www.no-ip.com
hostname you picked
username
password
And thats about it.
hostname you picked
username
password
And thats about it.
I think dyndns.com has free accouts, so you don't have to pay for basic stuff like dynamic DNS.
I use Dyndns and there is no need to setup anything in the router even. I just use a small program that update dyndns on regular basis with my current ip and voilà.
https://account.dyn.com/entrance/
Strangly they say that no-ip is free on their web page??
yea i have no-ip i know they have a free account but i got the pro account for being able to host web cams witch is my next projects so im sure when my wifi cams get here i will dig into it more i haven had time to mess with it due to my work flow this week..
but as a update for my wifi unit.. everything is running great no signal loss or disconnections so far and were on day 5
