port forwarding issues
so im trying to configure my wifi attachment. i spent allot of time messaging with rimai who has been a big help but i figured i post to see if anybody else has some input. i dont wanna bother rimai too much.
im having a issue with my port forwarding. i feel ive tryed everything ive used the simple port forwarding program. messed around with my internal and external ip address. after all of that i had it working then all the sudden boom it stopped working no matter what i do i cant get it to connect. the portal gives me a unreachable address error and the app gives me error 15 bad url.
i feel in my router (verizon Actiontec mi424-wr rev e) is screwed up some how does anybody have any idea how i can get it working?
Re: port forwarding issues
Have you tried the port forwarding video on this site?
http://www.actiontec.com/products/produ ... id=188#doc
You might also consider setting up a Dynamic DNS as well..That way your router updates the Dynamic DNS with your external ip address all the time..
i have done the port forwarding as showen in the video. i had not done the other option can u tell me more about it
thanks
thanks
I will check the manual for your router and let you know how to do it...
Have you checked to make sure port 2000 is still open? and you have port 2000 forwarded to the ip address of the reefangel wifi module?
Starting on page 141 of the manual it explains the 8.3a Dynamic DNS. It doesnt tell me what services your router will work with.. Basically you need to sign up for something like no-ip.com or whichever one works with your router.
it link u sent me states that my ports are closed but my router says there open. do i need to open my the port on my external ip as well
Nope.. Might check that you have the protocol right.. Can you post a picture of your port forwarding rule you setup?
To set up advanced port forwarding (custom ports):
1. Click the arrow next to “Application to forward…” and select Custom Ports
from the drop-down menu.Configuring Security Settings
6 6.4 Port Forwarding
110
© 2010 Verizon. All Rights Reserved.
2. Enter the host name (from the drop-down list) or local IP address of the
computer providing the service in the “Specify IP” text box. Note that only
one local network computer can be assigned to provide a specific service or
application.
3. Click Advanced.
4. Select the Internet protocol to be provided from the “Protocol” drop-down
list. Depending on the protocol selected, additional options appear in
the screen.
5. Select the connection with which this port forwarding rule will be active
from the “WAN Connection Type” drop-down list.
6. To select a port to forward communications to (this is optional), select
“Specify” from the “Forward to Port” drop-down list, then, in the text box
that appears, enter the port number. If no port is identified, select “Same as
Incoming Port.”
7. If this port will be active all the time, select “Always” from the “Schedule”
drop-down list. If the rule will only be active at certain times, select “User
Defined” and click Add. Then, add a schedule rule (for more details about
schedule rules, see the “Advanced Settings” chapter of this manual).
8. If source and destination ports need to be specified, select Specify from the
drop-down menu list (by clicking on the appropriate arrow), then entering
the port numbers.
9. Click Apply to save the changes. The new port forwarding rule appears in
the “Applied rules” table at the bottom of the screen.
110
application.
3. Click Advanced.
the screen.
Incoming Port.”
the port numbers.
i figured out that no-ip wil work for my router. but they want me to pay. im hoping theres a fix with out me having to pay anymore. plus i dont understand how this hole dns this works
Does the ReefAngel still have the ip of 192.168.1.3? Have you unplugged the wifi module? What color are the lights on the wifi module?
You only need the no-ip stuff if you want to access your reefangel from a the wifi module using an app on the iphone or android.. When your internet provider gives you a different external ip then your router updates it to no-ip and you can always get to your reef angel no matter what your ip address is? You just type the link in like example.no-ip.com and it would route it to your ReefAngel..
i get a slow blinking green light thats it no blue led.
heres what my router is picking up
PC Name: ReefAngelWifi
Connection Type:
Wireless
IP Address: 192.168.1.3
Status: Active
Remote Access: Enabled
Connection Type:
Wireless
Status: Active
thanks for the help by the way
No problem I'm not much help really.. Lol.. I still think it has to do with port forwarding..
What happens if you put the address of 192.168.1.3:2000 in your standard webbrowser?
You should get Reef Angel Controller Web Server
Looking at the picture you posted Can you change the port forwarding in your router Make 192.168.1.3:2000
when putting the ip int the web browser i get webpage not available. i dont understand what u mean by change the port forwarding
On the screen shot you posted of your router settings make the second to last line 192.168.1.3 look like 192.168.13:2000. I would save it and reboot the router. Then check and see if the port is open.
ok so i saved it and rebooted the router with no luck. port 2000 still closed
- Capture3.PNG (40.43 KiB) Viewed 4576 times
there has to be somthing in my router blocking my ports from opening. nothing opens any ports could this be somthing with my firewall?
Do you have a firewall? I also searched a bit last night before I fell asleep. It looks like a lot of people have trouble with port forwarding on that router. Where it shows in the settings that its forwarded but doesn't actually work.
when u say firewall do u mean the router right? if so yes it has a firewall but i have it set to the lowest setting to except all incoming and outgoing.
im still thinking it has to be this router not actually opening the ports even tho they have all been forwarded. since it a verizon router i cant just use another router. or can i? im going to call verizon and see if they can switch out my router i hope they will. because this sucks . i need to get these ports open somehow
DB thank u so much for helping me i really appreciate you giving me your time to help a noob.
i will call verizon and get back to u with what they say
I will read some more when I get home from work. Several of the posts I read online people have called verizon and verizon said to call actiontec, then they called actiontec and they said to call Verizon. Lol.
I'm wondering if maybe there's a software update for your router?
i tried to update the firmware of the router and it told me everything was up to date.
Do you have Verizon Fios? Maybe they can help at this forum. If not I would call Verizon as a shot in the dark.
http://www.broadbandreports.com/forum/vzfiber
Yes I do have Verizon fios. I briefly look at the links you posted and I will post on the forums after work. I think I'll also give fios a call to see what they say about the switching out the router. I been down this road before in that past during my pc gaming years. but never had a issue like this. This router is really killing me.
When I get home I'm gonna try to do a hard reset of the router and start fresh. While I spend a hour on hold with Verizon. How about the dynamic dsn do you think this would also help. if I have to pay for the service I will. I just really need to get this thing working.
Nope we can mess with the dynamic dns after we get port forwarding fixed first. No-ip wont charge. I have a free account setup with them.
Lets fix the router port forwarding first.
I also recall a problem with that router.
I think the issue was single ports....
Have you tried setting up as a range??? Except, start at 2000 and end at 2000. It's the same as single, but the router thinks otherwise... lol
- DrewPalmer04
My friend has one of those. Real pain. Do range forwarding. I think that's going to solve your issues.
OK I will try this when I get home today. Can one of u guys explain a little more what range forwarding is and how I get this done.
You guys here at RA forums are the best I knew I mad the right choice with this controller. Blows other controllers out the water
